Question about 1A Auto Parts 1995-1998 Ford Windstar Radiator w/ V6 3.8 232 All
Main rod bearing torque
Torque specs for main bearing caps
2 Suggested Answers
ryszardx
  • 94 Answers
SOURCE: I Have a 5.9l 360 v8 that just recently spun a bearing or 2.
Get some plastigauge at the auto store and measure the bearing to shaft clearance. You may need an oversize bearing if there is extended wear.
Posted on May 08, 2014
What is the torque specification for rod bearings and main bearings
Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Fixya
www.fixya.com/.../t15635769-main_bearing_bolts_torque_suzuki_xl7_...
Jan 2, 2013 - Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Suzuki 2002 XL-7 ...What are the torque specs for cam caps on a 2005 Suzuki forenza 2.0 ... Need torque specs for 1.3 liter motor,connecting rod bearing and main bearings.
Oct 07, 2015 | 2005 Suzuki XL7 - Without speaker - Carpet...
Main /con rod torque
Here are the torque specs you requested:
MAIN BRG CAPS= 29FT/LBS THEN TIGHTEN AN ADDITIONAL 90 DEGREES in sequence(two step process)
ROD BEARING CAPS= 18 FT/LBS
CYLINDER HEAD BOLTS= 29FT/LBS + 90 degrees + another 90 degrees in sequence from the center out ward, (3 step process).
Please let me know if you have any questions
Aug 22, 2015 | Toyota Pickup Cars & Trucks
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
I am looking for torque specs on a 91 honda prelude 2.1l.I need specs and sequence for the main bearing caps and rod bearings
the specs for the 1991 prelude with a 2.1 engine are, the connecting rod caps are 34 ftlbs and the main bearing cap are 49 ft lbs, hope this helps,
Sep 10, 2010 | Honda Prelude Cars & Trucks
Torque specs for 1.5 kia rio connecting rod
TORQUE SPECIFICATIONS kia rio
Cylinder Head Bolts:
(21.7ft.lb) or (3.0kgf.m) 90?
May 22, 2010 | 2001 Kia Rio
Need to know torque spec. on main & rod bearings 4 cycl.
1997 Nissan/Datsun Truck Pickup 2.4L SFI 4cyl
The Main Bearing Cap Torque:
38 Foot pounds (Final torque)
The Rod Bearing Cap Torque:
Torque sequence:
Step 1: Torque to 10-12 Ft/Lbs
Step 2: Torque to 28-33 Ft/Lbs
Hope help with this (remember rated this post). TY for using Fixya.
May 19, 2010 | 1997 Nissan Pickup
Need torque specs for 1999 Ford 3.0 rod & main bearings
ft lbs
Main Bearing Cap Bolts 75-85 56-62
Connecting Rod Cap Nuts 31-39 23-28
May 27, 2009 | 1999 Ford Taurus
Torque specs
2002 2.0L Duratech.
Don't have 2004 2.3L
  • NOTE: Use new connecting rod bearing cap bolts.
    NOTE: Do not fully tighten the connecting rod bearing cap bolts at this stage.
    Install the bearing caps.
  • Rotate the crankshaft through 180 degrees and insert pistons 2 and 3.
  • Position the corresponding bearing shells, clean and free of oil, into the connecting rod and the connecting rod bearing cap.
  • Coat the inner side of the bearing shells with engine oil.
  1. NOTE: The crankshaft must rotate freely, if necessary check and adjust the bearing clearances.
    Tighten the main bearing and connecting rod bearing bolts.
    1. Tighten the main bearing bolts in two stages.
      • Stage 1: 25 Nm.
      • Stage 2: 60 degrees.
    1. Tighten the connecting rod bearing bolts in two stages.
      • Stage 1: 35 Nm.
      • Stage 2: 90 degrees.
Apr 28, 2009 | 2004 Ford Focus
99 dodge intrepid specs
Inner main bearing cap bolts:
Torque to 15 ft-lbs, then rotate an additional 1/4 turn
Outer main (windage tray) bearing cap bolts:
Torque to 20 ft-lbs, then rotate an additional 1/4 turn
Main bearing cap cross bolts:
Torque to 250 in-lbs or 20.83 ft-lbs
Connecting road bearing cap nuts:
Apr 21, 2009 | 1999 Dodge Intrepid
Torque specs for 1998 tercel 1.5L
Main Bearing Cap Torque-42 Ft. Lbs.
Head Bolts Step 1-33 Ft. Lbs. Step 2- Additional 90 Degrees
Rod Bearing Nuts-29 Ft. Lbs.
Hope this helps
Apr 08, 2009 | 1998 Toyota Tercel
1A Auto Parts 1995-1998 Ford Windstar Radiator w/ V6 3.8 232 All Logo
324 people viewed this question
Top 1A Auto Parts Home Experts
gbob59
Vernon Taylor
Are you a 1A Auto Parts Home Expert? Answer questions, earn points and help others
