Question about Clarity Ameriphone Q90D Digital Cell Phone Compatible Combination TTY/VCO 79040.000
IPHONE NOT WORKING WITH TTY
Cant call
What is TTY Mode?
TTY Mode. A TTY (also known as a TDD or Text Telephone) is a telecommunications phone that allows people who are deaf, hard of hearing, or who have speech or language disabilities, to communicate by telephone. Your phone is compatible with select TTY phones.
Nov 16, 2015 | Cell Phones
People cant hear me wen im talkin to them on the phone.....
Go to systems "Phone" and make sure that TTY/TTD mode is not turned on. This can cause the phone to have the symptoms you describe.
Jul 14, 2009 | Palm Treo 650 Handheld
How do i get updates since i have vista
Updates are always available online.
If you try to add unathorized gadgets to your TTY, you could have problems. Always check the owners manual for "dos and don'ts."
Jul 09, 2009 | Ultra Products Tty Printing Tty Users...
Tty mode speaker problem
Go to menu; settings & tools; call settings; tty mode; select TTY OFF. It should be fixed.
Jan 27, 2009 | LG VOYAGER VX10000 Cellular Phone
No sound whatsoever on LG KG800 Chocolate Phone
easiest way to solve this problem. go to call settings and TTY mode. and switch it to TTY + talk ... if that doesnt work then fiddle around with the other TTY settings untill it does. this disables the earpiece
Dec 09, 2008 | LG KG800 Cellular Phone
TTY/ TDD Phones Question
TTD/TTY devices use normal phone lines to communicate. An individual with a TTY/TDD can either communicate with another TTY/TDD device or can make a call to a standard telephone. In this case, the TTY/TDD device calls a live relay operator and the live relay operator communicates with both parties either with a TTY/TDD device or uses their normal human voice on a standard telephone. It is important to note that there are different protocols that can be used to communicate with TTY/TDD devices, however many newer TTY/TDD devices can handle a wide range of protocols and can even communicate directly from a personal computer using special software and a computer modem.
Aug 27, 2008 | Clarity Large Visual Display for TTY
Iphone screen blank
hold the home button and the power button on top for about 8 sec at the same time u should get the apple logo on your screen, let go and let it run its course it should get ya going again. Hope this helps You all!!
Jul 14, 2008 | Apple iPhone Smartphone
Tty
Try disabeling TTY unless you need it it (it is a hearing impaired function). To disable do the following: In idle mode press the Menu soft key to access menu mode,
Select Settings and highlight Phone Settings,
Press the Select soft key or the Cingular key,
pres the 5 key and highlight the Disable selection,
Key in the password: 4889,
Press the OK soft key
For additional technical support call 888-987-4357
Jan 11, 2008 | Samsung SGH-d807 Cellular Phone
Clarity Ameriphone Q90D Digital Cell Phone Compatible Combination TTY/VCO 79040.000 Logo
257 people viewed this question
Top Clarity Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Clarity Health and Beauty Expert? Answer questions, earn points and help others
