Question about Samsung SyncMaster 220WM Monitor
Screen goes black after 10 seconds - Samsung SyncMaster 220WM Monitor
I have a very weird problem with my computer screen. When i start my computer it loads fine but after seeing my desktoop the screen turns black after 10 seconds. If i unplug and power supply of my screen...
what is the os u are using, mention ur operating system, it is just a screen saver problem, try it in properties by clicking left mouse button on the desktop, is there any error message on the desktop when u got black screen
Aug 07, 2013 | Computers & Internet
Tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
Vw42L tv comes on withpicture for 5-10 seconds and screen goes black ,sound is still on
Most likely you either have a defective backlight inverter, bad back lamp. Based off of your model #, I'm gonna lean towards a back lamp.
May 10, 2012 | Vizio Televison & Video
White screen on the iphone 3g
It's not 10 seconds. Hold down the home and the power button for about 15-30 seconds till the screen goes black. You will notice little lines in the screen, which is totally normal. Keep holding till the apple logo shows back up..
If it does not. Then your screen is probably out.
Nov 15, 2011 | Apple iPhone 3G
ALBA 32 INCH FLATSCREEN AFTER 10 SECONDS SCREEN GOES BLACK BUT SOUND IS FINE?
Check for dust blocking the air vents as this will cause the TV to over heat but I would expect it to take longer than 10 seconds.
Aug 13, 2011 | Televison & Video
Monitor goes black after about 7 to 10 seconds. I can turn power off and then back on and it will be ok for about 10 seconds before it goes black again.
Check whether the cable from the system to the screen is connected properly and there is not loose contact. Also take the system into BIOS and check whether the same issue is happening in the BIOS screen.Try a factory reset on the screen by pressing the OSD button on the screen.
Switchoff the screen and disconnect all teh cables including the powe cable and press and hold the power button for around 40 sec and now reconnect the cables and try to power up the screen
Jan 04, 2011 | Proview PL926WBi 19" LCD Monitor
After a few seconds the screen goes black
You need to restore the phone to the factory defaults. If this doesn't work, you'd have to bring your phone to someone that can update the phone's firmware.
Jul 14, 2010 | Sony Ericsson K850i Mobile Phone
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Open Questions:
I have a Samsung 220WM monitor that comes on for a second and then goes black, in that second I can see my logon screen and have typed my password in and the screen still stays black. I have tried hit I have even tried to restart my computer in Safe Mode because I thought maybe the refresh rate was set to high, but I only saw the screen flash and could not get any visibility on the screen to work with. I have also tried to get the monitor to do a Self Test, you know where you unplug it from the computer and turn it back on to see the little screen with the blue/green/red little square boxes...and I got nothing but a black screen. Which kind of tells me that somethings not right with the monitor because I have tried the monitor with 2 other computers and I have the same problem and a different monitor works just fine with either of my computers. (NOTE: I build/upgrade/troubleshoot compuer for 2 small businesses here in Charlotte and also have built some highend gaming Rigs for some friends/family and I currently have 3 working machines...but only 2 working monitors...LOL ) All running Windows 7 Ultimate. Anybody got any suggestions on how to fix this ? P.S. - the day this happened my screen flashed kinda wierd like and then that computer (Gigabyte MoBo w/ AMD Athlon 64 2.2Mhz OC'd to 2.9Mhz on water 4GB of Dual Channel, Windows 7) screen went black and the computer turned itself off and when I rebooted the monitor has been doing this wired **** ever since. I was kinda wondering if I caught some kind of virus/trojan that whacked my monitors refresh/resolution/sleep settings ? Any help would be great cause this has been a flawless monitor.
Sep 29, 2012 | Samsung SyncMaster 220WM Monitor
See all Samsung SyncMaster 220WM Monitor Questions
Samsung SyncMaster 220WM Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
