Question about Fujitsu Siemens Power Supply Module 500W hot plug for RX300 range of servers
FUJITSU S26113 power good
I have a fujitsu reverse cycle aircon AOT36RCD3L had power switched off for 5 hrs now compressor is not working self diagnosis is saying E 100 inside fan is still working what do you do to get it working...
Hi Mark,
I hope the following link is of some help for you?
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Feb 05, 2015 | Fujitsu Heating & Cooling
Fujitsu T4220 will not POST
may be you replaced with a bad one
Mar 26, 2014 | Fujitsu Siemens Computers & Internet
My wife's Fujitsu Lifebook A6120 has lost power. I suspect the problem is with the power cord or post as it is mounted on the side of the laptop. Is this a common issue with this model?
Yes, as a PC Tech, I have seen many Fujitsu Lifebooks, all bearing the same problem. The A/C power jack mount where the power cord connects to the notebook is very fragile and seems to become unusable after a period of time.  I repaired a whole sales team fleet of 19 units that were all Fujitsu Lifebooks and all with the same problem . . . damaged or broken AC adapter jack.
The solution is to reorder the power jack component (usually less that $10.00) - remove the faulty jack and replace it with the new one - however this is not an easy task unless you have good soldering skills.
You will need a low-temp soldering Iron and a service manual to show you how to dismantle the laptop and access the power jack.
I don't recommend novices techs to try this. The good news is that most PC repair places will fix the problem for less than 100.00. The bad news is you will eventually have this issue again in the future.
Hope this answers your question!
Mar 20, 2010 | Fujitsu Computers & Internet
Have Fujitsu P42VHA 10/W. Works for a few minutes
its a power supply problem ..check for leaky capacitors and dry joints ..farr64[colin] good luck
Dec 29, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
When I plug in my UPS if turns on and off really fast. I was wondering if it was shot or I just need new batteries. It has not been turned on in a year and was wondering if it was good or not.
Batteries sitting for that long are probably shot, if the unit was functioning correctly previously, most likely is just the batteries. The batteries are pretty cheap, but so are the UPS's themselves. If getting a new one is close to cost of batteries, just go with the new UPS to save a headache in case its not the batteries.
However, if the unit wasn't kept in a good environment it could be anything, condensation shorting or corroding circuitry, capacitors drying up, etc.
Oct 09, 2009 | Fujitsu APC Smart-UPS 3000...
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Siemens Power Supply Module 500W hot plug for RX300 range of servers Logo
99 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
