Question about Ovens
Jade rjd03003a fan
Fan operating except on fan only setting
Open the oven ,if you are a technician, check the cables for the fan switch and that for the heating filament are clearly seperated .
Mar 13, 2016 | Ovens
How to repair exhaust fan rattle?
You can look at fan closely and see if there is a set screw holding the fan to the shaft. It could be loose causing the rattle. If that is not the problem then see if the shaft has a lot of play in it. It could be worn out and allowing the fan to rattle. If that is the case then replace the fan
Apr 26, 2014 | Bosch HBL 642AUC Electric Single Oven
Oven shuts off with Error Code 4d21
This problem points to the controller card not functioning properly. It will need to be replaced. Here is a link so you can get the owner's manual:
http://www.manualslib.com/products/Jade-Range-Rjdo3003a-2904090.html
Check it out, it may help you figure it out.
Mar 19, 2014 | Jade RJDO3003A Stainless Steel Double Oven
I have a neff fan built in oven everything is working except the fan is it a matter of just replacing a new fan?
Make sure there is a supply to the fan before attempting to replace it, if there is and the fan does not work, then replace it.
If the fan element is getting hot, but the fan is not working, then you need to replace the fan motor assy.
It is a fairly straightforward repair, but remember that the fan blade assy is secured by a left hand thread, so unscrew the nut clockwise as though you were tightening it, holding the fan blades as you do it.
Jun 22, 2011 | Ovens
The oven leaks gas fumes into the house and will "blow up" if not opened every 30 minutes. it forgotten and left on for an hour, it may blow out from under. This oven was converted from natural...
incorrect conversion- valves to large - gas should not leak at all- should only FLOW when in use- TURN OFF GAS TO STOVE- EXTREME FIRE HAZARD
May 10, 2011 | Jade Ovens
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
I was baking something and all of a sudden the lights in our house went dim and our oven glowed bright orange and when I opened it, smoke came out but my food was still uncooked. Now the oven won't heat...
Sounds like you had an element burn out and tripped a breaker.
Find the breaker to the oven. If its tripped it should be in the middle position, not "off" they are sometimes easy to mistake for being on.
If you have a volt.ohm meter we can doagnose the problem and confirm if it is the element or not. (90% chance thats it.)
They are fairly easy to replace and usually pretty cheap.
But before you buy parts, make sure if its still under warranty or not. If it is, it could save you some time and money.
Jan 07, 2009 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
