Question about Tools & Hardware - Others
Planer Rattle My Delta 22-540 12" ''portable'' table top planer has started making a noise like a tumple-dryer containing a handfull of pebbles. Doing this even when no stock being fed thru - obviously more audible then. Bought it second hand a week ago. Used 3 times. Yesterday the noise started but went away. Now there all the time. Today gave it a good clean & lubes according to manuf instructions. Checked the rollers & blades. Could it be something in the motor?
  • yacht_neutro Jun 14, 2009
    HI
    Thanks. I did check the belt and it seems OK, tension OK as well, nothing jammign it & no dirt on it.
    Thanks, Guru.
    The speed of responses on this site are really impressive - guess its what makes a good site - good members caring about the others.
    And Guru no 1 for me.
    I have to admit that my first thoughts were related to something jammed and/or loose nuts.
    I did a good cleanout this afternoon with compressor & toothbrush & tightened everything I could find after stripping off covers.
    Tomorrow (or maybe later in the week as is WORK 2m) I will give another check for loose bits, jammed bits and a triple check on that belt. Past 9pm here, so will not be back in the garage tonight.
    THANKS!
  • 520 Answers
If it is belt driven then maby replace the belt. That may be the problem.
Posted on Jun 14, 2009
  • Chris  Jones
    Chris Jones Jun 14, 2009
    I also checked my jointer plainer and it has a loud rattle but it turned out to be a loose bolt.
How do I replace the infeed dolor on a delta 22-260 planer
Most parts bought will come with the installation instructions
Delta 22 560 Type 1 Planer Parts
Cheers
Billy of Hayward
Sep 26, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
My On /Off Switch needs to be replaced. I can not find a listing for this part. I have a 12" Portable Planer Modle 22-540.
Do you have a Delta 22-540 12" portable planer? If this is the correct make and model, then Sears Parts Direct has the parts you need in stock. Delta has issued a substitute part for the original.
The switch is part 159 here: http://www.searspartsdirect.com/partsdirect/part-model/Delta-Parts/Planer-Parts/Model-22540/1667/0734000/10052175/00003?blt=06&prst=&shdMod= . The key of the switch is part 160. Other sites also have the switch under the new part number.
I hope this helps.
Jul 10, 2011 | Garden
I have a delta portable planer model TP300 12".It
make sure the blades are seated and locked down correctly
Mar 15, 2011 | Delta Tools & Hardware - Others
The planner nips the end of the board
My planer does the same thing.
1) I don't make the final cuts on my boards until after planing.
2) I discovered why the planer does this. I don't have a planer table. I use the two metal stands that came with the planer, and they don't really hold the board flat & steady like a planer table would. The planer has 2 rollers >>> one roller is on the feed-end and one roller is on the finished-end. When the end of the board goes past the feed-end roller, it is no longer held flat by two rollers. The weight of the board causes the board to tip up into the planer blade on the last 3 inches. So sometimes I just hold up the end of the board as it finishes ... but it still takes a nip out of the board now and then.
Up-vote if the information helped you. Thanks for the feedback.
Oct 15, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
My 13 inch delta planer will not feed the stock through the planer. Any suggestions why?
I have a 12" Portable Planer Delta Model 22-540 - Planer will not feed the stock.
Sep 09, 2009 | Delta 22-450 20" Planer DC-580 3-Phase, 5...
How to change planer blades on the Delta PT400LS 12.5" planer?
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Nov 19, 2008 | Delta TP300 Shopmaster 12-Inch Portable...
Tools & Hardware - Others Logo
345 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
