Question about Noise Hush NoiseHh N780 Bluetooth Headset with Charger - Black
Noisehush N780 has blue light double flashing, why?
I came home to discover that my N780 had turned itself off (power was recently recharged). When I turned it back on a blue light started to do a double flash on a regular and continual basis. Why?
Hello, I have Hyundai Ductless Air Conditioner unit (model WSH-302BA) which has recently started turning on by itself at various times and blowing very cold air. When this happens all the lights on the...
The timer's circuit is malfunctioning. Replacing it will fix the issue. Meanwhile Try to unplug the power of the unit for about 3-5 hours then check if it fixes it. Double check the air filter if it's frosting.
Sep 05, 2008 | Heating & Cooling
Tip
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 | Radio Communications
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
I lost my manual and don't know how to pair the headset to a new phone
Turn unit on - hold function button for 10 seconds
Led should flash red -blue-red-blue ...
on your moble device go into the search function
passcode 0000 (4 zeros)
if successful only the blue led should be on
Apr 07, 2011 | Naztech Noisehush N700 OverHead Bluetooth...
Jvc th-s3 won't turn on...blue light flashes briefly and then goes out
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
May 13, 2010 | JVC TH-S3 System
Creative zen connected to my computer but i can't explore it
I recently charged my friends zen for him and the power was run down, the blue light u see is normal it is just recharging, just wait for about 20-30 minutes for it to charge a little and turn the power on, it will still charge.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
Noise Hush NoiseHh N780 Bluetooth Headset with Charger - Black Logo
41 people viewed this question
Top Noise Hush Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Noise Hush Radio Communication Expert? Answer questions, earn points and help others
