Question about HP Officejet 5610 All-In-One InkJet Printer
Error message " cartridge not intended for this printer" have been using the same cartridges now i get this message
  • 10 Answers
SOURCE: Cartridge is not intended for use in this printer
Under the setup menu, then under preferences, there's an item where you can change the language & country. I don't know if that will have any affect on the cartridge selection though.
Posted on Mar 15, 2008
hashchathy
  • 246 Answers
SOURCE: I'm getting a message on
Please try to reinstall the printer driver
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
bhagyavichar
  • 414 Answers
SOURCE: message :-cartridge is not intended for use in
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed and call ur system admin....
if all the above fails, then it may b a defective or demo cartridge..!!
Posted on Oct 26, 2009
Riztech
  • 731 Answers
SOURCE: printer says-
Please change your ink cartridges, using printer with empty or low ink; could damage the printer.
Posted on Jun 16, 2010
Testimonial: "thanks for that we will try that."
Help me please, i have new HP j3508, but when i install new cartridge into my HP 3508, the message on the screen says :"Cartridge Error" cartridge on right is not intended for this printer... help me
You need to remove the cartridges, see to it that the colored cartridge are olaced in its right location the same as with the black cartridge to avoid an error.
Jan 09, 2013 | Office Equipment & Supplies
Error message the following ink cartridge is not intended for use
I would replace the ink cartridge in question because each one has it's own circuit board and it appears you have a conflict in the printer.
Mar 06, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
HP OFFICEJET 6310 ALL IN ONE CARTRIDGE ERROR: "CARTRIDGE ON RIGHT IS NOT INTENDED FOR THIS PRINTER" USING SAME CARTRIDGE ALL THE TIME. WHATS THE DEAL
The printer has detected that you are using a refilled HP ink cartridge.
HP stated on their ink cartridges as Intended for single use only.
If you use it a second time, it would be Not Intended for this printer.
If the cartridge has not expired and was not refilled, you could call HP for a replacement.
You coud also try to remove and install back the cartridge.
Reseting the printer by turning the printer off then on may work.
Jan 09, 2011 | Office Equipment & Supplies
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
The following print cartridge is not intended for
Take it back, might be the wrong one, or manufacturer's defect?
Mar 14, 2010 | HP Office Equipment & Supplies
Cartridge error
the contacts are old on the cartridge. try a new cartridge or clean the old cartridge contacts with a pencil eraser.
Jul 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
284 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
