Question about Candy Washing Machines
Where is the filter on WM 1000 C1040
Won't pump out
Why dosent. My washingmechin spin
Wm has 2 drain first before spin. Check drain pump filter is clean . Located front bottom of wm.
Aug 11, 2014 | Kenmore Washing Machines
My LG WM 2010CW washing machine is showing this error "OE".
You have some drain problem, check drain pump, drain house, filter
Good Luck
Mar 15, 2013 | Facebook Apps
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
How do i access my dryer filter
On the front at the bottom left is a rectangular panel that you pop off. (I use 1/2 a wooden laundry clip so as not to scratch finish.) Have a bowl or a bucket handy and perhaps a towel or two. There is a tube clipped to the washer. Detach from washer and unplug it and let water drain into your bowl. When water stops flowing, plug and reattach. Then (with towels ready) turn the the pump filter counter-clockwise (the circle to the right of the tube) until it comes out. More water will drain in this process. Clean the filter of any foreign objects. Replace and turn clockwise until it won't turn any more.
Apr 17, 2011 | LG WM-3677HW Front Load Washer / Dryer
Washer has water still in drum and OE on digital readout
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | LG WM-2277HW Front Load Washer
What does OE stand for on my washer
Hi
Thanks
Rylee
Jun 15, 2010 | LG WM-2277HW Front Load Washer
I have an error code "oe". in the past we have installed a new rotor, stator, wiring harness and control board. it was a load of towel, so i unloaded half and tried again. no luck. "oe"
Hi
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
Hi
Thanks
Rylee
Intellowasher WM-1460 FHD
Try cleaning out the drain filter and see it that fixes it.
Nov 17, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
