Question about HP LaserJet 1018 Printer
Printer does not print scanned objects
The printer was initially installed in windows XP. I have installed it in Windows Vista Home Basic now.
My printer prints from word document but I have to send the command twice. It does not print from scanned documents. When I select print for the scanned document, a "print pictures" window opens that does not show my printer as installed. The printer is otherwise detected through control panel - printers.
    Scholar:
  • 169 Answers
Try uninstalling the printer drivers from the device manager and then try reinstalling it.seems to be an issue with the printer drivers.
If you wannt any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
  • 2072 Answers
SOURCE: document jam
There is a sensor in the document feeder that most likely is stuck on the frame or the spring fell off and is not resetting. Have you taken a minela folder and run it through the feeder to be sure there is not a small fragmant of paper on the sensors? If you havent try that, or a piece of paper folded in half twice and keep sliding it though the feeder.
You would have to take the feeder apart to get the sensor set, That is best accomplished by taking the back cover off, then the left side cover, ( looking from the front) and disconnecting the feedder connectors, then removing it from the scanner.
Posted on Apr 07, 2008
acdr
  • 1913 Answers
SOURCE: I Shared Olivetti printer between 2 workstation(Error)
then pls explain in brief.
Posted on Jan 05, 2009
d2704
  • 101 Answers
SOURCE: I have to hit print twice for printer to print document
Try to install new cartridges, possible ends inks.
Since level of the ink is specified for orientation aproximately
Posted on Mar 07, 2009
sonu_sehgal
  • 421 Answers
SOURCE: hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Posted on Jun 03, 2009
azeroth009
  • 65 Answers
SOURCE: Get paper jam message, paper
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  1. Turn off the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  1. Turn off the printer.
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Posted on Feb 17, 2011
Testimonial: "Thanks a lot, I found a tiny piece of paper that was preventing the carriage from moving freely."
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
HP IIP printer prints spaces where ink should be. Letters are incomplete, jumbled. A fixer problem??
Oct 27, 2010 | HP LaserJet IIIp Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Black lines on scans and prints HP 2727nf
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
Will not print. Have to power off and then power back on for printer to start.
Oct 27, 2010 | HP LaserJet P2015dn Printer
Is there any hope for a Vista 64 bit HP Laptop with the HP LJ 2840 Printer? I have tried it all, had Invisus Support work on it for two hours today, 10-25-10, and still no printer functionality. I am...
s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
Oct 26, 2010 | HP LaserJet 2840 Printer
Hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Oct 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
