Question about Tiger Kitchen Appliances - Others
PDHB22U need rubber gasket
Hot water dispenser need to replace rubber gasket
ThaMp3Doctor
  • 8596 Answers
SOURCE: RUBBER GASKET ON BOTTOM OF GLASS JAR NEEDS TO BE REPLACED
It looks like their parts are handled by Fox International. here is the contact info:
For parts and accessories for your household appliance, please visit our partner, Fox International, or use the following.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Email: customerservice@georgeforemancooking.com
Posted on Mar 31, 2009
  • 14 Answers
SOURCE: 12 cup brew station there is a rubber gasket
You can;t replace the gasket or reinstall it. Mine did the same thing. Call Hamilton Beach customer service at 1-800-851-8900. Tell customer suppot what the problem is and they will most likely send you a whole new tank for the cost of shipping which is only $5.00. Apparently this is a common problem so they stand behind their procduct by replacing the tank for free plus cost of $5.00 shipping. I love Hamilton Beach!!!! Katherine
Posted on Jul 13, 2009
woobie dog
  • 1273 Answers
SOURCE: Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Posted on Aug 08, 2009
beltronic205
  • 1474 Answers
SOURCE: Lg. amt of water in soap dispenser after each wash.
Could be floor leveling ..Adjust and try
Posted on Oct 03, 2009
Testimonial: "Thx, won't worry about the water puddling in door boot seal, am concerned about water in soap disp., will see if there was an issue with installation"
SOURCE: lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Posted on Feb 02, 2010
Sunbeam hot shot leaks
Unfortunetly, most modern manufacturers do not supply replacement parts, however if the unit is still under warranty, you could probably have it replaced for free. Contact the manufacturer or retailer.
Nov 16, 2012 | Sunbeam Hot Shot Hot Water Dispenser Black
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
Oct 03, 2009 | Washing Machines
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Water runs out of the rubber gasket inside the door
replace water inlet vale it has gotten debris in it and not allowing it to close
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Problems with Black & Decker #900144 TopLoad Water Dispenser: It is dripping water constantly and the item is only 4 mnths old
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whynter FX-6SW Free Standing Hot & Cold...
Lg refrigerator water dispenser would not shut off
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Kitchen Appliances - Others Logo
60 people viewed this question
Top Tiger Kitchen Appliances - Others Experts
Irene Tulloch
ray gallant
Bill Boyd
Are you a Tiger Kitchen Appliances - Other Expert? Answer questions, earn points and help others
