Question about Dewalt Dw359 Circular Saws
Motor quit running
Saw quit running during a cut as if an internal breaker was tripped.
2 Suggested Answers
tomgswan
  • 30 Answers
SOURCE: Brand new saw trips 20
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Posted on Jul 01, 2011
What caused my bosch matter saw to quit cutting in middle of the cut
Several possibles:
1) Load exceeded circuit amps. Breaker tripped.
2) Load exceeded saw amps. Reset tripped.
3) Wiring failure in saw.
4) Wiring failure in supply.
Time to start checking.
Note- if the blade is dull or the load on the saw is too great it will trip one of the breakers.
Mar 26, 2016 | Bosch Saws
Brand new out the box dw716 dewalt compound dual bevel miter saw cut one board & quit. Left it alone for about 10 minutes & it worked when we came back. Made about 10 more cuts & it stopped again. We are...
I would return it to the store, or have it fixed under warranty. You obviously have a defective saw. Dewalt is a reputable company, and they make high quality tools, but defects do op up once in a while from all manufacturers.
It sounds like your saw has a defective heat sensor, and it is sensing the temperature incorrectly and shutting the saw off to protect it.
Dec 12, 2014 | Saws
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Mar 12, 2011 | Makita K06 Switch 5007fk 5007nb 5007s...
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Ryobi circular saw --it keeps tripping my breaker
Possible bad circuit breaker. If on a ground fault sensing circuit, the saw may have electrical leakage from it's internal wiring/motor to case ground (a possible problem if you have been using a metal cutting blade)(test by using a 3-pin to 2-pin adapter [no ground pin]). The circuit breaker may not be rated for the starting load of the saw (check the saw load rating against the breaker current rating--the breaker rating should be at least 25% higher). Possible excess current draw in the saw if any of the motor windings have shorted together for whatever reason. Hope this helps!
Feb 06, 2010 | Ryobi Circular Saw W/Dual Laser
14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 29, 2009 | Delta Saws
Delta Radial arm saw 33-990 tripping circuit breaker
More than likely motor but try this , if you have a wrap around amp probe or can borrow one or purchase a cheap one place the amp probe around the positive wire connected to panel breaker ,with meter on proper scale ,start saw and read probe current , if cap bad current will be high and stay until breaker trips , if motor will start high on start ,then low then ,very high and breaker will trip , be careful in panel working around live circuits , the reason it reads this way is because as the motor warms the laminates it the armature separate and cause the increase in current to spike ,if cap bad never gets to speed and has high current draw constantly , to verify cap(1) remove from circuit (2)place a screw driver across terminals to release any charge (3), then take ohm meter on ohms place meter leads on terminals one on each terminal at same time meter will rise and fall back(4) reverse leads and should rise and fall as before if it does this it is more than likely good a lot of electrical reasons for this but this will tell you what you wanted to know , good luck
Dec 08, 2008 | Saws
Dewalt Dw359 Circular Saws Logo
43 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
