Question about Creative WP-350 Headset
Headset no longer turns on after recharging.
Is headset repairable
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
My blue tooth - plantronics explorer 232 has a constant blue light. I can't get it to turn on or off. Please help.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Good luck from Headsets Direct!
Aug 02, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Here is the link for the Plantronics 220 User's Guide.
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 360 bluetooth headset will not come on
Try letting the battery die completely on the headset then recharge it and see it it will then turn on.
Mar 13, 2011 | Plantronics Explorer 360 Bluetooth Headset...
I have a question my name is gloria it is regarding my Plantronics Voyager 500A. Customers have problems hearing me I have checked the volume and it is on high and it also cuts in and out. I have noticed...
Start by checking the connections on the base. Make sure the AC power adapter for the base is still plugged into the base and a wall outlet or power strip. If you are still not getting any lights, either the power cord or the base have gone out and will need to be replaced. If the headset is dropping the calls, try resetting the headset to the base.
Other things that could be causing the headset to drop the calls is that you are getting too far away from the base; if you move back in range, it should pick the call back up.
Also the battery could be dying in the headset and is no longer rechargeable. The battery is not replaceable in the headset. The headset will need to be replaced.
Aug 26, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Microsoft Wireless Headset
Thank you. In the meantime I returned the headset to the store.
I will not need it.
Oct 11, 2008 | Microsoft LifeChat Rechargeable Wireless...
Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
May 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h500
Delete it from your Razr, turn off the bluetooth and recharge it to full. Try pairing it again. Make sure you enter the passkey correctly. Check the manual for the bluetooth if you dont know what it is. It is usually 0000.
Dec 30, 2007 | Motorola Mobility Bluetooth Hands Free...
Creative WP-350 Headset Logo
Top Creative Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Creative Radio Communication Expert? Answer questions, earn points and help others
