Question about Staples ID Armor SH2836ID2836 Shredder
Wont turn on after overheating even after an hour
Green light but no action could the fuse be bad
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
My LG 42LC7D tv wont turn on. The green led lights but no picture or sound
There could be several things going on, I would start with having the power supply checked. I've worked on several LG sets from that time frame that all had bad capacitors in the power supply causing all sorts of issues
Nov 27, 2012 | LG 42LC2D 42 in. LCD HDTV
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
My ps3 wont turn on. light turns green, flashes
This is known as the yellow light of death.(ylod) It's about 150 bucks to have it serviced unless it's still under warranty.It says in the manual it is an overheating issue.
As for your problem, call customer support at 1-800-345-SONY
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Unit will not power on.
its probably not the battery, your gps should run even without a battery if the power port/circuit is ok. unfortunately this is a common problem that the usb port gets damaged with this and many other model of magellans gps systems.
if you had it plugged in to the car charger, make sure the green light is on while charging, if its not, you might have a blown fuse in the charger or the fuse for the cigarette adapter in the car.
if the green light is on, try letting it on for a few hours, then try and turn it on. if and when it turns on, you can verify if its charging by going to the system settings then the power option. the battery bar should turn green and move from right to left if its charging. if the battery is slightly low but the bar is not moving left to right, then its not charging.
you can check the charging by using the usb cable provided with your unit and hook it up to your computer to verify if its charging. but i suspect it has a bad power port (usb connector)
i hate to be the barer of bad news, because rarely do i get a good rating for being the barer of bad news, but hopefully you just have a bad charger or a blown fuse in your adapter or car.
good luck
bill
Oct 19, 2009 | GPS
Every several hours the screen goes all blue, and the set turns off.
overheating in back get fans and clean it out dust before it gets worrse
Jan 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Staples ID Armor SH2836ID2836 Shredder Logo
59 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
