Question about Apple MC677LL/A iPhone 4 16GB Verizon Smartphone -White
How to remove sim card?
There is no pin hole on the side.
Hows sim card goes in lenova
Look for a small hole in anyone side of the devide, Insert the pin you got with the tab into that hole to open the sim tray. Put the sim in that tray and push it back to the slot.
Sep 29, 2017 | Cell Phones
How to replace a SIM card in an Apple 5C?
about half way down on the right side is a slot cover with small pin hole. push an unbent paperclip or similar into hole and it will pop out.
Jul 08, 2016 | Apple iPhone 5c
Where is/how do you remove the sim card and memory card?
on you Samsung Galaxy A3 smartphone, your SIM card and microSD card are both on the side of the phone where the power button is. They will be located closer towards the middle (microSD) and bottom of the phone (SIM).
you will need to use the pin hole tool or you can use a small paperclip or a pin to pop out the tray that holds them.
see the tutorial (silent) video for a visual how to explanation:
How to put sim card and memory card on Samsung Galaxy A3 A300F
Dec 01, 2015 | Samsung Galaxy A3 A300
Remove sim card
take a push pin and insert it in the hole on the side of your iphone. the sim card will then pop out
Feb 06, 2014 | Apple Iphone 3gs Model A1303
Remove sim card tray carefully
its there left of side of the phone its look lik a tin hole sww\\ee and put a pin there it ill be open
Dec 30, 2013 | Apple MD440LL/A iPhone 4 8GB CDMA Verizon...
How to remove sim from iphone 4
If you use an original version if Iphone 4, just take a paperclip or pin and with the pointy tip, press slightly the button / hole located on the right side of your device. The card will eject in a drawer-like compartment.
For cloned Iphones, just slide the back of the device, remove the battery and remove the sim/s at the top.
Jan 21, 2013 | YouTube Videos
How do i insert a sim card for iphone 4
insert a sharp hair pin into hole present by the side of the phone.sim tray will be ejected out.place your micro sim in that and push it in.
Nov 20, 2012 | Apple iPhone 4 Black Smartphone
I need to put sim into iphone
U need a pin or a small paperclip. On the right side of the phone there is a hole. Push pin or paperclip in that hole. **** in and the sim card will pop out.Good luck
Nov 29, 2011 | Apple iPhone 4 Black Smartphone
How do you put the sim card in the apple i phone 4
Apple iPhone 4 uses a Micro SIM which is 15 mm × 12 mm in size while the standard Mini SIM is 25 mm × 15 mm in size. To insert a SIM in iPhone 4, follow the steps below:
  1. Take a simple paper clip and make it straight.
  2. Check the right side of your iPhone 4 to locate the SIM tray on the Right side of the iPhone.
  3. Insert the pin into the small hole and push it slightly until the tray pops-out. Now pull out the Sim card tray with your hands.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 10, 2011 | Apple iPhone Smartphone
How do we put the sim card in
on the Apple iPhone 3G Black Smartphone u will receive a pin the the box insert the pin on the top of the phone where u will have a small hole and will will get a slider to insert he sim try this and tell me incase any issues
May 04, 2010 | Apple iPhone 3G Black Smartphone
Apple MC677LL/A iPhone 4 16GB Verizon Smartphone -White Logo
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
