Theratherm controller error
Error message on theratherm heating pad
Sunbeam heating pad model 828-511 is showing F2 on controller
Hello, Pat -
I can only find that the F2 error code means there is "a problem;" not what the problem is.
I suggest you go to this Sunbeam web page for your model of heating pad:
http://www.sunbeam.com/pain-relief/back-and-spine/sunbeam-microplush-body-shaped-heating-pad-with-digital-lcd-controller/000828-511-002.html
You should see a link for "Live Chat" on the right side of the page. Click or tap on "Live Chat" to text with a Sunbeam Customer Service Representative. He or she should be able to explain the F2 error code and what can be done to correct it.
Best wishes.
Mar 07, 2018 | Office Equipment & Supplies
Why does my heated mattress pad read "error"?
Hi, I think that Your mattress pad possibly low quality or it was error by manufacturing company. They couldn't maintain proper quality. So this mattress pad may harmful for you health. You may get new best quality mattress pad. Also I think this website www.bestmattresslist.com may help you. Best Mattress Topper Archives BestMattressList
Oct 09, 2016 | Sealy Heated Full Size Mattress Pad - -
DJO Global
Joy, Re POST , make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 07, 2016 | Theratherm Digital Moist Heating Pad,...
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
Picturemate printer; how do you reset ink pad counter; or how do you get rid of the error message so you can continue printing
Hi
You need a reset ink pad software to get rid of this error message. Since you do not put the printer model and number. Try this link for epson printer only. http://www.ssclg.com/epsone.shtml. If not, use websearch to find your free software resetter for ink pad error message.
Let me know if you need more help
Mar 12, 2011 | Office Equipment & Supplies
Error Message F2 E6
Perform the following actions to fix your error:
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'Upper Cancel key ' function and wait for 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thank you !!
May 30, 2010 | Whirlpool RBD305PR Electric Double Oven
Getting F1 error message
F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself.
Mar 11, 2010 | Ovens
F1 error on heating pad
Unplug & then plug in... will help for a little while, but the F1 will return. Sorry.
Oct 07, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
