I am unable to open my micro sdhc card when i insert it into my laptop. It does not write the name of the card it just write Security digital memory card. It also states that it is full in the properties. when i look at the drivers it states that they are wiorking properly. when i put the card into my nokia 6500 slide it reads that its half full but when i open it, it will be empty. where have all my data gone? Pliz help
SOURCE: Micro SD not reading
If you are unable to access/view the contents of the card, chances are, it needs to be reformatted for it to work again, which means, data will be loss. You may, however, try to search the web for a data recovery program which you can first try to use before reformatting the drive.
SOURCE: change in sdhc memory card capacity
Go to the scandisk website and get the format tool.
If you got this card for something besides computer,you use the devise to format card and not the computer. Ex-phone.
Format card with phone.
If you got this for computer,you should have gotten a flash drive.
SOURCE: Sandisk 4GB card reads full when it's empty.
I would suggest reformatting your disk to your camera. We have had those issues and it has cleared it up. Be sure any pics on your camera have been backed-up as you will loose all pics while reformatting. The key is to reformat your disk to your camera (use the camera's menu to located the reformat disk section)...do not use the computer. Hope it works!
SOURCE: 4gb micro sd card says its "full" when its empty
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
