Question about ADATA ASH14-1TU3-CBK Hard Drive - Superior SH14 1 Tb 2.5" External Black USB 3.0 SATA 5400 rpm 16 Mb Buffer
My Adata Superior Sh14 is being read but nothing is being displayed? I don't see where it is connected.
When I connect my hard drive it does not show up on my desktop as usual to indicate that it is connected or accessible to me.
Why is my pc saying not reading source file?
If it reads some things on that drive, the file may be corrupted.
Jul 10, 2014 | ADATA DashDrive 1TB HD710 Military-Spec...
It can't be initilized
All I can suggest is to check the connections of your USB and Power Supply. If everything is ok, you should find someone specialized in recovering data from Hard Drives with access problem.
Jun 17, 2014 | ADATA A-DATA Nobility Series NH92 500 GB...
Driver for adata c008/8gb xp sp3
Try looking here:
http://www.adata.com/index.php?action=ss_main&page=ss_content_driver&lan=en
Mar 24, 2014 | ADATA Classic Series C008 Retractable 8GB...
Adata superior SH93 on macbook pro cant see drive
If the drive is formatted for anything but a MAC, for example Windows, The drive will be seen but not data will show as the mac cannot read most Windows file systems. Try connecting the drive to a windows machine and see if the data can be read.
Mar 10, 2014 | ADATA Superior Sh93 500 Gb External Hard...
File system lost?
I recommend SpinRite from grc.com. It is the most diligent utility I have used for this. Explore and understand the explanation of what it does on the website.
Jan 12, 2014 | ADATA 1TB Classic CH11 Black External Hard...
Driver for adata superior sh93 500 gb external for windows 8
you dont need a driver.
i cant find SH93?
the top complaint it the USB cable is no good.
or falls off, or likes to get half/inserted and fail.
try a new USB cable.
see if windoz (is it on a mac?) disc managment can see it.
see if windoz) lick USB task bar icon can see it. (1st)
when you plug it, in to USB port (yes, try them all, and other systems.) the USB port goes dingdong, (connect sound)
does it?,
if , not it for sure did not connect. fix that first.
Sep 29, 2013 | ADATA Superior Sh93 500 Gb External Hard...
System not recognizing external device
I understand by "external device" is that your none of your USB ports work and you can't use your CD/DVD burner
Get a Hard Drive to USB connection, they are cheap and you can get one in any computer store, remove your HARD DRIVE from your Compaq and connect it through USB to your new computer. You can copy all your data and still continue using your old herd drive as an external drive.
Sep 28, 2013 | ADATA A-DATA Nobility Series NH92 500 GB...
Hard drive not getting connected to my laptop
if you don't show a hard drive in your pc than follow this step
step 1: first go to start than
step 2: run this command compmgmt.msc than
step 3: you see tree view menu,go to the disk management than
step 4: you see removebel drive than right click on it and after change drive latter
Feb 01, 2012 | Transcend StoreJet 320 GB USB 20 Hard...
ADATA ASH14-1TU3-CBK Hard Drive - Superior SH14 1 Tb 2.5" External Black USB 3.0 SATA 5400 rpm 16 Mb Buffer Logo
100 people viewed this question
Top ADATA Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
dmhandyman
Are you an ADATA Computer and Internet Expert? Answer questions, earn points and help others
