Question about Brookstone Cloud DSS Long-Range Copter
Cloud dds helicopter parts
Where can I get parts (Stabilizer Bar etc) for Brookstones Cloud DDS copter
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
Power Window System Controls
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
How do you charge the cloud dss helicopter
The copter's battery is charged with an ac adapter power unit model number - 3PL0508S, hope this helps.
Jul 05, 2014 | Brookstone Cloud DSS Long-Range Copter
Need parts /brookstone cloud dds
Go to Ebay and search for replacement parts for the Double Horse 9116. They will fit your Copter. I have four of them. Also visit www.propelrc.com. and browse spare parts and find your model.
Mar 28, 2014 | Brookstone Cloud DSS Long-Range Copter
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Oct 07, 2008 | Olympus DS-30 Digital Voice Recorder
Brookstone Cloud DSS Long-Range Copter Logo
23 people viewed this question
Top Brookstone Televison & Video Experts
Tom Chichester
Mister Danger
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
