Question about Kenwood Fp480 Fp580 Fp680 Fp690 Fp910 Bowl Lid Genuine
Safety interlocks my interlock become active.how can i fix it?
I bought a new interlocking collar for my Kitchenaid blender, and now it doesn't seem to be fitting on the base properly. It's resting on the base rather than going all the way down, if that makes sense....
Remove the collar from the jug and have a good look inside, there is a circular ring inside the collar that needs to engage correctly with a glass finger on the jug. The glass finger goes between 2 plastic fingers. I think there are two of them. It was a silly idea that's been given the flick on later models.
Mar 02, 2015 | KitchenAid KSB560 5 Speed Blender
The blade won't 'lock' on my kitchenmaid food processor. It is new.
The blade off the shaft or on it will not prevent the processor from starting. The safety interlocks are on the bowl, lid and pusher so look there for the problem.
Feb 20, 2015 | KitchenAid Kitchen Aid KFP715OB - Food...
Why is my food processor not work but Light is On
Maybe the bowl is not properly activating the safety switch.
Aug 31, 2014 | KitchenAid Kitchen Aid KFP715OB - Food...
How to
I would suggest just replacing it. It can become a shock hazard in its current conditon.
Jul 23, 2014 | Kenwood kMix BLX50 Blender, White
Power comes on but when any of the other knobs are pressed it not coming on
Sounds like the safety button under the locking tab is not making completely - or the tab is broken.... Machine will not "run" without this safety tab making contact.
May 25, 2014 | Cuisinart Blenders
Magic bullet
Blenders usually have some sort of interlock that prevents power from being turned on if the container is not locked in place. This could be the reason for the problem
Apr 25, 2013 | Emson Magic Bullet Express Blender
I broke something when I was putting the jar on my bosch MMB1000 blender and then it didn't start after that. I thought that I had broken the safety and when I open it up I saw a small broken plastic thing...
Without seeing the part that is broken it is hard to say what exactly the problem is. But it sounds like it is one of the safeties. Look on the bottom of the jar to see if you can see where the plastic broke off of. If not then the plastic is probably the safety inside of the lower part of the unit.
Jan 07, 2011 | Bosch MMB1000 Work Top Blender
First time i used new machine did not go on model rhbirey 3029778
Look for a safety interlock switch that requires the bowl to be FULLY engaged before it will run.
These are OFTEN hidden a bit for aesthetics.
Dec 22, 2009 | Russell Hobbs 3902US Work Top Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Spare part availability
check the door interlock switch.
Mar 07, 2009 | Dynamic MD95 Handheld Blender
Kenwood Fp480 Fp580 Fp680 Fp690 Fp910 Bowl Lid Genuine Logo
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
