Question about E-Machines T2542 PC Desktop
Power switch (E-Machines T2542) is broken. Will not turn on again after turning off. Have to leave computer on all the time because afraid will not be able to turn it on again if I turn it off. Anyone know where to get replacement switch?
    Problem Solver:
  • 10 Answers
I don't have the same model as you, but I think you're having the same issue as me. I'm assuming the switch on the front has physically "stuck" in the case? First of all, restart your computer and enter the BIOS. This is usually done by hitting the Del, F1, or F2 key as it is starting up. It may even tell you which key to press as it is starting. Once you're in, look around for the setting which governs what the computer should do when power is lost. Adjust the setting so the computer switches itself back on when power is restored, then hit F10 to save your settings and exit. If someone shuts the computer off after this, you can get it back on by switching it off at the wall for 5 minutes and then switching it back on. The PC will register power loss/restoration and hopefully come on on its own __ As for an actual solution, I can't find spare parts. In the end, I cut a hole in the front of the case and wired my own switch in. If you decide to go this route, it is better to use a biased switch ( http://en.wikipedia.org/wiki/Switch#Biased_switches ) as it mimics the function of the original. You might be able to temporarily fix the stuck switch by taking off the little silver cover with the 'e' on, then using a paperclip, pencil, or screwdriver (all of which i have used before) to pull it back into its original position. Hope this helps
Posted on Jun 15, 2009
Computer does not power up
Probably a dead power-supply.
Take the computer to any computer-store,
so that they can remove it, match it up with a replacement,
and install the replacement power-supply.
Oct 09, 2010 | E-Machines T2542 PC Desktop
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
Aug 17, 2010 | E-Machines T2542 PC Desktop
Is there a reset button to start the power on the computer? When I push the power on button, the computer does not turn on.
You can try a couple of steps before.Romove the battery only and try to start it with just the AC only.If this fails try step two.Remove the battery and the memory.Press and hold the power button down for twenty seconds.Replace them and try again.Step three remove them again,this time remove the hard drive and the cd romas well as the battery and the memory.Press and hold the power button down for twenty seconds again.If this fails chances are the motherboard needs to be replaced.
Good luck
Oct 22, 2009 | Dell Inspiron B130 Notebook
I just lost all my cd 's with my emachine t2542,i re install new W XP OS because my hard disk was damaged and replace new one,the problem is,it's usb ports doesn't work,help me pls.tnx
In order for us to assess possible drivers that are available for the eMachines T-Series T2542, please download the trial of Driver Detective and run it to ensure a more accurate list of drivers for your computer with less chance of error.
http://www.drivershq.com/Drivers/eMachines/T-Series/T2542/22605/22647/22688/Drivers.aspx
Oct 05, 2009 | E-Machines T2542 PC Desktop
Computer wont boot up
If you have one of those generic motherboards with Intel chipset, socket 478, 2 or 3 PCI slots in a mini ATX form so, don't waste your time and buy a new one. Some time ago I replaced it with a cheap Biostar P4M80-M4 and is much better.
Oct 04, 2009 | E-Machines T2542 CELERON 2.5 GHz 256 MB 40...
Machine won't turn on . Period
Could be a bad power supply or a dead cpu. I would start by changing power supplies with one that is working if you have a spare computer with an ATX power supply. It is nolt very common but could be as simple as a defective power switch. How does the switch feel when it is pushed? Does it spring back or feel like something is broken. Most of the time when I have repaired a PC that does absouloutley nothing when the power button is pressed....dead CPU. You could also try leaving the plug disconnected for 20 minutes....maybe something in the powers supply is heating up. They will store power even when the computer is off.
Sep 13, 2009 | E-Machines eMachines Desktop PC
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Nov 17, 2008 | E-Machines eMachines Desktop PC
Emachine T2542 Won't power on
you need to open the PC and check the power supply for some fuse and safety device that acts like a fuse , these fuse looks like a 3 leg transistor only that it have 2 , look for this , and of course the typical fuse . hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
Emachine not responding
Sounds like intermittent power supply. Power supply not putting out required voltages.
Apr 05, 2008 | E-Machines eMachines Desktop PC
E-Machines T2542 PC Desktop Logo
100 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
