Question about MSI G31M3-L V2 Motherboard
Code 10 U S B easy transfer cable
What are the steps to download photos from phone to computer?
If you're using an Android phone, that's easy! First, connect your phone to computer, then select the MTP or PTP mode on your phone. Then you can transfer files between phone and computer casually.
If you're using an iPhone, you will need some tool. Like iTunes, iCloud, FonePaw iOS Trasnfer etc which can help you transfer files between iPhone and computer.
First download the program, and connect your device as well as the Android phone. Then select the files you want to transfer and that's OK. The steps to download photos from phone to computer is easy.
Nov 11, 2010 | Computers & Internet
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
TRANSFER TO WRONG EXTENSION
This will be an easy fix. It is your night AA selector code. Did you resolve this?
Apr 07, 2009 | AT&T Lucent Merlin SP 34 Phone
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Easy transfer cable
Too risky as the cable may or may not be configured for two of the same OS.Transference by CD would be a better option.
Sep 19, 2008 | Computers & Internet
Easy Transfer cable issue
You can download "Windows Easy Transfer" for free from Microsoft or from most manufacturers of "Easy Transfer Cables". Good luck, the software is ****.
Mar 16, 2008 | Computers & Internet
MSI G31M3-L V2 Motherboard Logo
22 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
