Question about Nautilus T916 Treadmill
.'i have MTR OVER HEATING PROBLEM...
I have MTR OVER HEATING PROBLEM...
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
Fan spinning backwards
If its the original mtr. or was working fine before then mtr is bad replace mtr with new capacitor
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
Motor is not coming on
Sounds to me mtr. may be bad. If u have a meter & know how to use set meter to read ac volts next disconnect plug that goes into mtr. check to see if voltage is present if so bad mtr. i would even try to spin mtr see if it gets going but most likely need to replace
Apr 04, 2012 | GE Refrigerators
Blower fan does not work?
wiggle the connection at the blower mtr .make sure all the fuses are good even take a hammer and lightly tap blower mtr...If that doesnt help and power is present at blower mtr connection then blower mtr needs replaced
Feb 17, 2011 | 2002 Dodge Caravan
Heater not blowing out
locate the blower mtr under passenger side of dash and check for power there ..if there is 12 volts then blower mtr is bad . if not check blower mtr fuse in fuse panel
Feb 16, 2011 | 1999 Oldsmobile Intrigue
Heater Fan Motor stops working
fan mtr needs to be replaced. If you locate the mtr under dash on the passenger side or under hood. then wiggle wire connector or lightly tap on the mtr. if mtr. cuts on and off you have found the problem
Feb 16, 2011 | 2000 Oldsmobile Alero
Fan not working
check sensors on engine or possible broken wire to fan mtr
May 21, 2010 | 1999 Ford Crown Victoria
Healthrider s5001 treadmill stops during workout, shuts down. Will run for appx. 10 min.
check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
Jan 08, 2010 | Quantum ® 3.3ESD Treadmill
1999 lincoln navigator driver side window not working
Most likley the window mtr. If you can get the door pannell off, you can unplug the mtr and run a hot and ground wire to the mtr to see if this will run it. You may have to reverse the wires to make it run the othe way. If you can run the mtr this way the switch is your problem, if not its the mtr.
Sep 04, 2009 | 1999 Lincoln Navigator
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Nautilus T916 Treadmill Logo
15 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
