Question about Nintendo DS Lite Console
R4 Problem loading error
R4 Problem I recently received an R4 it came with the R4 2GB kingston Micro SD and a Micro SD Usb 2.0 reader. It came with no disc. I have downloaded various kernels and softwares but none seem to work, after turning on the DS the screen flashes and loading is stuck. I have used WinRar to extract documents from kernals and Roms. I have no idea what make the card is as i received it as a present with no box.
    Sniper:
  • 58 Answers
Get this file
extract the file with winrar, and copy the files to the DS card. The file structure should have is:
Files
  • _DS_MENU.DAT
  • _DS_MSHL.NDS
Folders
  • _system_
  • moonshl
You should now put your .nds files onto the root of the card also, and hopefully all should work OK for you
Posted on Jun 20, 2009
Ave got a r4ds card but cant get games to work do i load them as rar files or do i extract them to get them to work
Posted on Jul 17, 2009
I bought R4 cards for DSlite and 4gmicrosd formatted sd to fat downloaded kernels for R4 loaded games onto sd card put all together all I get in the Dslite is loading...nothing more it will not go any...
Hi denise, amh, could you please specify what r4 model you got? because there are lot of R4 out there, but the original R4 team had stopped producing R4's, all we have mostly today are clones. now some R4 only recognize up to 2GB of sd/micro sd cards, try using 2GB then see if that works..
Dec 02, 2011 | Nintendo DS Lite Console
R4 ,When switching on ,SD error shows then
This sounds like a problem with the MicroSD card in the R4. Some brands have been known to be incompatible. Without knowing more information about the R4 and the SD card
A couple of years ago, I had three microSD cards fail, even reformatting failed. I believe it was a problem with the R4's at the time. Try reformatting the microSD card in a PC, download the latest kernel and load that on to the microSD card, if you can get it to format.
Failing that, buy a new SD card. SanDisk/Transcend and Kingston are the preferred and recommended types. Is this an R4 or R4-SDHC? Don't use an SDHC(4gb+) memory card in a R4, only in R4-SDHC.
Memory cards are cheap enough 1gb-2gb don't cost that much, if you have an R4-SDHC then try a 4gb
I take it it was working at some point or other, or is this a new card?
Apr 30, 2010 | Video Game Consoles & Games
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
Can I use Kingston 2GB micro SD in Nokia 2680 mobile phone. And what is the adapter and how and where is it used? Thank you.
 the nokia support micro SD then you can introduce in the slot on the side on the fone , and that's it your done
Nov 22, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Oct 14, 2009 | SanDisk 2GB microSD Memory Card
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
Scandisk 2gb says menu when I switch on.
If you are using the sandisk 2 GB with an R4 card it is not possible. R4 cards and sandisk micro sd cards aren't compatible. Buy a Kingston 2GB micro sd card that should then work.I hope this helps you. If is does please rate me.
Jun 23, 2009 | Nintendo DS Console
4G micro SD
i had the same problem, my 2 gb would work ok but not my 4gb i have heard that the 4gb wont work on the older r4's, so i bought a ds Lite R4 Revolution III (Version 3) from amazon.co.uk and it came with evrything you need and it worked great the address is https://www.amazon.co.uk/s/ref=nb_ss_w_h_/275-1618189-4849908?url=search-alias%3Daps&field-keywords=DS+Lite+R4+Revolution+III+%28Version+3%29&x=14&y=15
Nov 03, 2008 | Nintendo DS Lite Console
R4 SD card
you may have a r4 sdhc card that needs diverent soft ware go to www.r4sdhc.com
Jun 18, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
2,143 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
