Question about Philips CDR802 3-Disc CD Recorder
Cd burner not working
Burnt out lenz
My burner keep saying bad disc about every 2 disc
It may be because the disks are being burnt in quick sucession, not allowing your computer to clear the buffer or temp memory of the drive in order for the new data to be burnt to disk to be buffered.
Or your computer is too slow.
Allow a bit of time between each burn, say 15min.
Take care!
damnor01
Sep 12, 2012 | PDE Technology ZipSpin DVD CD Master...
My cd burner not working
What software are you using to identify & collect the files to be burnt?
Does the error happen after you click "burn these files to a CD" ?
What error-message do you get?
For $40, you can purchase a brand-new CD/DVD writer, to replace your current device,
which is less expensive than taking the computer to a technician for trouble-shooting.
Jan 10, 2011 | Dell Computers & Internet
Does not read burnt discs? how do I fix it
It may the problem of lense inside DVDRW which helps to read the cd if the lense get spoilt the DVDRW wont detect burnt discs
Aug 19, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How to clean the lens from the inside
you can purchase lens cleaner Cd from market but best way to remove your CD rom cover and clean the lenz manually with lenz cleaner liquid are available in market or just use tissue paper.
Dec 06, 2009 | InFocus Computers & Internet
Press play and get err messages
You could try cleaning the lenz for the lazar p/u on the inside with alcohol & a Qtip.. ie small circle lenz..
If that doesnt work - then most likely the lazor p/u has failed..
Hope this helps !!
Pleaase rate me good ;o)
Jul 11, 2009 | Curtis CD149 Personal CD Player
Laptop CD/DVD drive Can't read cd/dvd
Try cleaning the DVD with a CD drive cleaning disk.
Jun 28, 2009 | Compaq Computers & Internet
My gsa h54n dvd writer cd not reading but dvd
Sounds like the drive either doesn't like the disk you are trying to use or the cd laser has burnt out. Try the disk in another machine if you can, if it works ok then replace the drive.
Jun 08, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
My CD-RW/VD-ROM is not reading cd or dvd
on my DVD-rom,
it says 0 free space and 0 used space when i pressed properties
help me???
Aug 17, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Asus CDRW
Sounds like the laser is burnt out. I would replace the drive.
Oct 11, 2006 | ASUS CDRW 52X32X52 CRW-5232AS BK RT...
Philips CDR802 3-Disc CD Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
