Question about Sebo Vacuums
No power sebo model # hs 370
The brush on my Sebo 370 will not spin anymore.
Take the machine apart and take the belt off.
Try the motor and see if ti spins easily.
If it does, you have a binding brush that needs to be cleaned or replaced.
If it does not, and the motor is binding, it is time to shop for a replacement vacuum
God bless your efforts.
Oct 28, 2017 | Sebo Vacuums
My sebo x4 bagged hoover is losing power, what could the problem be
Is it a Sebo , or is it a Hoover. It can't be both . "losing power" ??? Motor comes on and off ? or stops picking up ? Be more specific please.
Oct 20, 2013 | Sebo X4 Bagged Upright Vacuum
SEBO 360 will not run when turned on. How do you test power cord and switch?
here is a video that will demonstrate how to check cord and switch
Jan 08, 2013 | Sebo 370 Bagged Upright Vacuum
Hi, I've just had my Sebo X4 back from being repaired (motor was growling so Sebo replaced it FOC under warranty) however, the replacement motor is 1000 watts. I queried this with Sebo, as they c
Watt= volts x amps So what are you losing? Not much really. Should they replace it with the same motor? Possibly, but you got a free motor out of them. To be honest I think you're splitting hairs on this one. The difference in how much cleaning that sebo will do with one motor vs the other is beyond minimal. The aggressive brushes on that vacuum do 95% of the carpet cleaning and both motors will have no problem turning it at sufficient speed. As far as suction goes I'd be amazed if it was even a noticeable difference. That's an amazing vacuum you bought, I wouldn't worry about it and go on with life.
Good Luck
The Vac Dr.
Nov 12, 2012 | Sebo X4 Bagged Upright Vacuum
My sebo x5 power head goes up and down without stopping
Hi There,
Sounds like you have a faulty control board in that one. You need to contact a sebo service centre unless you are comfortable repairing this sort of thing. If you need sebo parts in Australia check out VacuumSpot.com.au
May 12, 2012 | Sebo X5 Extra Bagged Upright Vacuum
My sebo airbelt k2 won't start
Hi It could be two things = one problem is that the cord in Sebo's K model has a bad habit of shearing thanks to its auto pull rewind mechanism. This would have to be replaced by a Sebo repairer.
Or it could be the actual electric socket if the bonded plug is loose - if there are wires visible at the end of the plug then the plug would have to be replaced. Its a common fault on Sebo's K models when the power stops thanks to shearing cords.
Mar 22, 2009 | Sebo Air Belt K2 Bagged Canister Vacuum
SEBO POWER BRUSH MACHING
Greetings from GoVacuum,
I wanted to show you where you are able to purchase this great product. I do sell this exact product on our website. If you haven't purchased the unit yet, let me know, I can offer you free shipping.
The product you are asking about is sold here;
http://www.govacuum.com/seducacl.html
This is an excellent machine, I personally have this machine, and I have been extremely pleased with
the way my carpets look after using it.
GoVacuum.com
Aug 26, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
SEBO Power Brush
Hi.
Hold A straight edge over brush head EG ruler.
Now rotate brushes slowly by hant they should just touch the ruler, If there is a gap then brushes need replacing.
http://dysonmanuals.llc.nu/index.htm
Chris.
Mar 14, 2008 | Vacuums
Windsor sensor sr12
There is a downloadable manual from http://www.windsorind.com/ go to documents, and note it is in alphabetical order -- so page through to "sensor" or you can search on the word "sensor" (don't include SR12). Also excellent training video on youtube http://www.youtube.com/watch?v=ikhtNFEKpeg.
I think, but not validated yet, that the Sensor SR12 (residential model) has been discontinued as I found it listed in their manuals under the discontinued section as well.
Jan 28, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuums Logo
18 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Andrew Taylor
Andrew Taylor
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
