Question about Sharp EL-2630P Calculator
How do I use the rate setting key?
I can't use the rate setting
How do i change the tax increase rate on my sharp EL-1197pIII
Move 'GT' '.' 'RATE SET' selector to 'RATE SET'
Tax / discount rate: • Press the TOTAL key twice, enter the tax rate, followed by the TAX+ key. •
Press the TOTAL key twice, enter the discount rate, followed by then TAX- key • A maximum of 4 digits can be stored (decimal point is not counted as a digit). Note: • Be sure to set above noted selector to the "•" position after storing an each rate. • For the conversion rate and the tax / discount rate, a single value can be stored for each. If you enter a new rate, the previous rate will be clear
May 27, 2016 | Sharp El1197P111 Printing Calculator
I have a casio dj-120 and want to set the tax rate how do i do this
Hold the rate set[%] key for 2-3 seconds.
Press the tax key.
Input the tax rate.
Press the rate set[%] key.
Aug 03, 2011 | Office Equipment & Supplies
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
Oct 19, 2009 | Casio Office Equipment & Supplies
Resetting the tax rate
Hold "set" key until "set exch" appears. Then hit "tax+" key and enter
in correct amount. After amount set then hit "set" key once again to complete set up.
Try that, seems to work on a few Casio models
Jan 02, 2009 | Casio MS-80TV Scientific Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Jan 05, 2008 | Casio HR-100TEPlus Calculator
Set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Nov 27, 2007 | Sharp EL-2630P Calculator
RE: CASIO CALCULATOR MS-80TV
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Oct 16, 2007 | Casio MS-80TV Scientific Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
Sharp EL-2630P Calculator Logo
13 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
