Question about Dell Latitude E4310 Laptop
Several of my keys will not work when my machine is undocked.
Only certain keys will work when my computer is undocked.
2 Suggested Answers
  • 58 Answers
SOURCE: black screen- undock the computer message
go to safe mode and return the settings back to day when it was all working fine. Use system restore.
Posted on Feb 16, 2008
IS UNDOCK ENABLED OR DISABLED ?
1. From the Start menu, shut down, then restart the OmniBook.
2. When you see the HP logo, press F2 to enter the BIOS Setup utility.
3. Select the Security menu.
Under Password Required To, choose when the password will be required.
Boot. Requires a password when booting the OmniBook. This option enables the next
two options.
Resume. Requires a password when resuming from Suspend.
Undock. Requires a password when undocking the OmniBook.
See the Manual for more details.
two options.
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=31634&docId=emr_na-bpi04015&docLocale=en_US
Mar 04, 2015 | HP Omnibook 4150 14.1 in. Flat Panel LCD...
Toshiba undock
Hello Eleanor,
By your question I can not tell if you have used the docking station or not so here is the removal procedure for a Hi Speed Port Replicator II
To disconnect the Port Replicator, follow the steps below.
1. Set the computer lock to the unlock position.
2. Make sure you perform
one of the following:
• Save all your work.
• Turn off the computer's power in any mode: boot, suspend or hibernation.
• Perform any software disconnect operation required by the operating
system.
• Press the eject switch.
CAUTION:
Make sure the Eject LED is out. Do not try to disconnect the
computer while the Eject LED is glowing.
3. Pull the eject lever out towards you to disconnect the computer.
4. Lift off the computer
Now if there are further problems or this did not help you please post further information like at what step did the station not perform correctly. Hope this helped.
Nov 29, 2013 | Computers & Internet
Laptyop D630 once undocked - trouble to conenct a projector ...
Basically you most likely have a corrupt hardware profile. Delete the profile for docked and try again, this normally works.....Mark
Aug 19, 2009 | Dell Latitude D600 Notebook
Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Jun 28, 2009 | Dell Latitude D600 Notebook
Turn off laptop to undock/dock?
Yes, You can just push the big "undock button and undock it anytime.
However, if you are using a "hardwired" internet connection, you will lose connectivity.
Otherwise, it is perfectly fine to do so.
Rick in Phoenix
Apr 02, 2009 | Dell D/Dock Expansion Station Docking...
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Docking Station problem
You can try to update any system utilities drivers and docking station drivers. However, I found that with IBM and Gateway, when you remove a running machine from the docking station they tend to glitch just a bit and when you redock them they have issues. Your issue is the docking station attachments, I've also seen issues with the monitor only, mouse only and keyboard on the laptop, all not working. I've had a couple that if I used the "safely remove hardware" then they would work when removed then redocked, but not all machines give the safely remove hardware option with the docking station. If yours does, try that. If it doesn't and there are no driver updates or the updates don't work, then, unfortunately, I'm afraid you'll just have to live with restarting after every redock. One other thing you might try is, after redocking, do a hardware search. It may find the attachments. I know this is also a pain, but it may be easier than rebooting every time.
Jul 09, 2008 | IBM ThinkPad X61 PC Notebook
Usb port dont work
Usually issue might be BIOS and Chipset related
first of all ensure if your BIOS is up to date, latest released version is Flash BIOS v1.3505, If yours is below this update the BIOS
next step will be updating the Chipset (Intel Chipset driver v8.0.0.1009)
Both of the drivers are available. I am adding the direct link for your convenience. Here is the link;
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=5924616&CFTOKEN=73863150
Please post more if you need further assistance.
Good Luck
Jan 10, 2008 | Acer Aspire 5100 Notebook
Black screen- undock the computer message
Oct 30, 2007 | Dell E173FP 17" LCD Monitor
Dell Latitude E4310 Laptop Logo
12 people viewed this question
Alun Cox
