Question about IMAGISTICS 794-3 toner for im3510 im3511 im4510 im4511 - 25,000 page yield -
Replace toner warning wont shut off
How do I get the replace toner field to shut off
Why it prints grey background
Either the toner cartridge is very close to empty or the drum unit needs to be replaced. Check your warning lights. Yellow = toner, red = drum. If no warning lights, pull out the toner/drum unit and remove the toner cartridge. Have a look at the cylinder in the drum (DR2125) - if it is very black and matt looking you will need to have it cleaned or just replace it.
May 20, 2014 | Brother HL-2170W Laser Printer
Tip
How to avoid U2 error which require you to replace toner chips.
This tip is proven in our machines could it be AR, ARM or AL series. To avoid the error above refill the toner cartridge ahead of time before the triangular dots(toner low warning in red light) gives warning. Just estimate the level of toner by checking your page count from previous refill. Failure to do so will require you to replace the crum chips or the entire toner cartridge.
on Jul 20, 2012 | Sharp AR-M205 Copier
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
Waster toner box to be replaced warning on a konica minolta C360, the warning doesnt go even after emptying the box, the warning still appears.
in waste toner box plastic transparent tube is there open that and clean and blow air through whole container and try it
beacause that plastic cap told machine there is waste toner is present or not
Aug 16, 2013 | Canon imageRUNNER C2550 Color Copier
I have a code E000013-0001 code showing on Canon 6055i copier
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Apr 24, 2013 | Canon IMAGERUNNER 6570 Copier
Epson C2600N waste toner collector full warning, after replacing the collector
Victor_Ott:
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
Brother 9460 reset toner
Like most laser printers, the toner light comes on early. This gives you time to order new toner. I find it best, since it does not stop the printer from printing, just to have a toner on hand and when your toner is empty replace it. Since this is a mesurement inside the toner cartridge its self, there is no way to reset the warning (other than replace the cartridge).
Feb 13, 2012 | Brother MFC9460CDN AllInOne Laser Printer
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
LEXMARK C500
If you open your printer front and pull out all the toner cartridges, on the left, you will see 4 LED lights vertically in a column that match up with 4 matching red light receptor sensors on the right side. Each toner cartridge has a tiny window on each side. When the toner powder level drops below the window level, a light passes all the way through the cartridge from the LED light to the light receptor and trips the printer to display the low toner warning.
The goal is to BLOCK THE LIGHT. The easiest way is to put electrical tape over the window on the right side of each cartridge window. To ensure you have the proper hole, just shine a flashlight in the hole and you will see the reflection from the tiny plastic window.
Jun 14, 2008 | Lexmark C500n Laser Printer
IMAGISTICS 794-3 toner for im3510 im3511 im4510 im4511 - 25,000 page yield - Logo
Top IMAGISTICS Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an IMAGISTICS Office Equipment and Supply Expert? Answer questions, earn points and help others
