Question about Wahl Sterling 2 plus Hair Trimmer
Black plastic switch has broken
Switch is to loose and won't stop on
My lawnmower won,t start
Three things I know to check. 1. check for broken kill switch wire or loose connection on same wire. 2. check for loose or corroded wires on switch. 3.If this unit has a stator and mag polish the surfaces of both and check clearances.
Jun 21, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
The washer turns on and fills up but then stops. If you bang the lid a few times it will usually continue on the cycle and be fine. You have to repeat the lid banging for every load though. The lid...
Sounds like the switch that the lid presses is either broken or has been knocked loose.
Or the little plastic or metal "switch actuator" (the little poker) that presses the switch has broken.
I believe the washer thinks the lid is open because it will fill up but wont't wash until it knows the lid is shut.
Jul 18, 2011 | Whirlpool Washing Machines
Hello. My HQ7830 on/off switch has stopped
This is a Quadra Action model and this is somewhat common. Most likely, the actual switch is not the problem. More likely, the problem is the plastic post that is between the button you push and the switch inside. Open up the shaver to take a look at it. The clear plastic post is probably either broken and loose inside or has gotten out of position ans is not making contact with the switch.
Replacement parts for this are no longer available so your only hope is to rig the plastic post somehow so that it will make contact with the switch. I've never had any good luck in doing this. It is possible that you may have to replace the shaver.
Feb 22, 2010 | Philips Philishave HQ7830 Electric Shaver
The keypad is working but the turntable doesn't move. The inside lights are not coming on and food stays cold.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
May 24, 2009 | Emerson Black Microwave Oven
Dacor Microwave PCOR3OS will not heat/tunrtable not turning
This Dacor model is very similar to Sharp model R1874.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the
free Adobe Reader to view or print them.
This is probably a bad secondary interlock (lower door switch) or possibly its mount is loose or broken.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 16, 2008 | Dacor PCOR30SS Microwave Oven
Door switch black connectors bad?
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Microwave Ovens
Microwave automatically comes "on" when door is closed, but no heat.
I have the R-1460 in the same series with the identical symptoms. After reading MicrowaveSvc's solution I started taking apart to view the door switches and found the upper door switch to be the problem, but not a switch failure a support failure. A small bottom plastic support post that holds the switch in place was broken (probably from repeated use/abuse) allowing the switch to move when the door hooks were engaged, thus not actuating the button switch. Since the problem was mechanical rather than an electrical bad switch, I made a small support arm for the switch from an old plastic mechanical pencil and glued it in place to hold the switch in its correct position. Problem solved, microwave works! Thanks to MicrowaveSvc's description of door switches.
Mar 14, 2007 | Sharp R-1460 Microwave Oven
Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
Sep 23, 2006 | Samsung SMH7159 Microwave Oven
Wahl Sterling 2 plus Hair Trimmer Logo
29 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
