Question about Powerwinch Boating
Free wheel sticks
Cable drum sticks at same place each revolution
How do I adjust parking brake
If Disc brakes jack up wheels , make sure the cable is not binding or frozen , pull hand leaver on three clicks, adjust cable till brakes just start to bind, release hand brake and check the wheels are free to turn. Drum brake check cables are free, back off cable till slack, check lining to drum adjusters are free and adjust if need be, pull hand brake on three clicks, adjust cable so brakes just start to bind release hand brake and make sure the wheels are free to turn ,
May 27, 2015 | Cars & Trucks
Rear drum brake locked on a 1998 volkswagen jetta
You could try momentarily releasing the bleed nipple. If that frees the brake it is a hydraulic problem causing it to bind.
You might have assembled wrong and should take a look at the repair manual or compare with the other side but most commonly such problems are caused by the handbrake cable or levers not fully returning or being adjusted to tightly.
When working on a drum brake the cable adjustment should be fully released before finally fitting the drum and then the brake pedal should be pressed hard several times and then the cable readjusted and the brake checked for correct operation before fitting the wheel. Any problems then are obvious before it goes anywhere near the road.
Jun 18, 2017 | 1998 Volkswagen Jetta
My 1992 Honda Accord sat for awhile and now the left rear wheel is locked up. Any thoughts. Thank you.
Your car has drum brakes on the rear. Did you have the parking brake engaged during the time it sat? If so the parking brake lever probably rusted in place. You might be able to loosen the cable at the drum. Otherwise, you need to remove the wheel and drum to free up the parking brake.
Jul 08, 2011 | 1992 Honda Accord
Hi i have just baught a gz 125 y marauder only to find that the cable for the rear brake is sticking, which is keeping the rear brake pads pushed against the drum. Will i have to buy a new cable and if so,...
hi, you could try lubricating the cable first with some lite oil, or wd40 or similar, are you sure it is the cable and not the brake shoe cam, try undoing the cable, push manualy on the arm from the rear brake drum, doing this will eliminate the cable being the possible cause, when you push on the lever on the rear brake drum with the cable undone from it, the arm should return freely when pushed or pulled, if it is seized at this point you will have to remove the rear wheel,remove the lever from the cam drift out cam from hub, and clean and lubricate before reasembly, when replacing the cable it is important you alow at least 10mm free play in travel, and check for free movment of wheel before use, also ensure you have enough travel to alow operation of rear brake light.
Jan 02, 2011 | 2000 Suzuki GZ 125 Marauder
Rear brake sticking
Your saying as you drive it locks and skids? You say as you try to pull out the wheel is shuck and it won't turn? Or your saying that you detect that the wheel is dragging and the wheel turns fine? Is the other rear wheel sticking? The parking brake pedal is it all the way up? With the pedal up are the parking braek cables under the truck going to rear wheels tight or taugt but moving or slack and hanging. As this cable enters the hosing going to the rear wheel about an inch from the housing ( cable Housing ) clamp on a pair of vise grips or other locking pliers and hit them with a hammer towards the rear wheel. As your trying to make the cable go back as much as it's going to. Check both sides as it's possible that thier frozen in the cold weather. It's wise to avoid using the parking break in cold weather as they get mositure in them over time and with them frozen on the brake wil stick. If you find the cables slack with the pedal released and beating them back towards the wheel does'nt seem to be releasing the break you may need to heat the cable with a tourch to free them. The other answer is the rear break came aprt someway and the break shoes are bound up against the drum. The wheel bearing is possible too unless you can tell is the break.
Dec 12, 2010 | 1990 Chevrolet K1500
Cirrus 2000 rear brake jam
if it's drum brake, remove the drum and check for dust collected inside the drum. also check the emergency brake cables for free of rust and are not binding
May 25, 2010 | 2000 Chrysler Cirrus
Rear left wheel locks and skids...drum brakes...
Hi:
You could have a parking brake cable sticking, or just your rear brake is over adjusted. Rear brakes can be adjusted in, and after the rear drum is removed, the parking brake cable should be checked to see if it moves in and out. Replace if needed!
Dec 01, 2009 | 1998 Chevrolet Cavalier
How do i remove the rear brake drum on a 04 ford transit
If you can't get emergency backed off to allow for movement, then you'll have to get small pointed object (screwdriver or whatever) in adjustment hole to lift lever holding adjuster wheel, then back off adjuster wheel at same time until free. If it's emergency cables seized at backing plate area, try spraying where cable goes into sleeve with penetrating spray, and rap sleeves of cables going into backing plate with a stick, or screwdriver handle and it may help them retract enough to loosen up shoes in drum. Good Luck.
Jun 20, 2009 | 2002 Ford E350
Car sat for 2 months with parking brake on
If you have steel wheels I would remove the plastic hub cap and hit the wheel close to the center without hitting the lugs with a sledge hamer a few times to release the rusted bond.You may want to try to grab the parking brake cable near the wheel and move it around first to posibly loosen a frozen or stiff cable.
Aug 23, 2008 | 2005 Chevrolet Cobalt
How to put front breaks on a 1999 chevy automatic cavalier
Place the bike on a stand, disconnect the cable, remove the wheel, set the wheel brake side up, use the bolt slightly inserted in the drum, or two oposing screw drivers around the drum to pull it from the wheel. Once pulled, remove the springs and shoes,lightly sand the inner drum on the wheel, install new pads and springs, spray both drums with brake clean, reassemble drums and wheel, install the wheel, and then adjust cable tension and brake pressure at first the wheel, and then at the bars. Test and readjust as needed.
Jun 17, 2008 | 1999 Chevrolet Cavalier
Boating Logo
19 people viewed this question
Top Powerwinch Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Powerwinch Boating Expert? Answer questions, earn points and help others
