Question about Smartpool Nitro Robotic Cleaner and Caddy
Smartpool model 7640 is not working and has swelled
Need replacement power supply
Envy 7640 how do i get print preview
Select "File" from upper left corner of the computer screen, it is in the menu that drops down.
Apr 26, 2017 | Office Equipment & Supplies
Toshiba lcd # 42hli67 blimks orange light and wont turn on
Thats usually caused by the power supply having bad capacitors. It could be the power board itself that needs replacement if the caps all look good with no swelling.. If you need a power board you can get one from www.tvrepairworld.com
Nov 07, 2012 | Toshiba Televison & Video
Help with standby power problem on 3M Replacement Lamp Kit EP7640ILK Projector Lamp for MP7640I ... ...standby mode with the power light flashing again.
the lamp for 3M 7640
USD110
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Mar 14, 2012 | 3M Replacement Lamp Kit EP7640ILK...
My Nitro Wall Climber will not seem to turn on. It will work one day and then I cannot get it to work again. Randomly it will respond to my effort to turn it on. The red or green light comes on but the...
Thank you for posting your question here on Fixya.com.
The best answer I can give you is that any number of components can cause what you are describing and most of them are not do-it-yourself repairs.
You can contact Smartpool directly for initial assistance in troubleshooting your cleaner. You can reach them at 1-888-560-7665.
If you have a voltage meter try to confirm you are getting ~30 volts out of the power supply with either light illuminated. If not the power supply is failing intermittently. It is more likely the trouble is in one or both motors in the cleaner and/or the cable itself...those items require more extensive testing and would mean the unit needs to be sent in for repairs. Smartpool can recommend the closest service center if need be.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jul 24, 2011 | Smartpool Nitro Robotic Cleaner and Caddy
I own a Sharp Aquos LCD model LC46D43U. It's 3 1/2 years old. When I turned on the TV, the power does not come on. It clicks like it's trying to power up and repeats itself 4 or 5 times every 4 - 5...
there is a problem with the power supply. most likely too much ripple that is ac leaking into the dc. I have seen the power supply repaired but it is not always possible. If there is an obvious swelled capacitor on the power supply that can be replaced this will be the best bet for repair. If there is nothing visually obvious then it gets a little harder since you won't really know which component is not working, the tv shuts down on a protection circuit so if the power supply can be repaired and the voltage "cleaned up" then the tv could work again. I have also seen replacement power supplys sold.
May 26, 2011 | Sharp Televison & Video
LG RZ 20LA90standby light flashes from red to green
Hi, this description usually indicates power supply failure, you can verify this by checking the output voltage of power supply. Cause of the error can be electrolyte capacitors. You can identify them by swelling at the top of the condenser. If you have the technical ability? so there are a few more options for testing. In any case always possible to replace all power supply. Good luck! Let me know if everything worked out, or if you need further guidanc
Feb 28, 2011 | LG RZ-20LA70 20 in. LCD Television
Need to order new bag,where, how.
The SmartPool website has an option for entering your zip code and finding a dealer/repair service in your area. They will carry replacement parts for this pool cleaner.
http://www.smartpool.com/website/#
Aug 01, 2010 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Nitro Robotic Cleaner and Caddy Logo
290 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
