Question about Worldwide 1994 Ford E350 Econoline Super 7.3L Alternator
Transmission E40D My Over Drive Light is flashing and transmission is jumping on the changes and work hard. please help me
  • Worldwide Master
  • 9,742 Answers
Look for a blown fuse. it's usually the same one that powers the speedometer.
Posted on Mar 20, 2014
1991 Ford F150 4wd 5.0 engine, tranmission E40D. overdive light brink off and on. put it in gear and the motor want to strall. already replace a solenoid inside the transmission didn't fix the pro
Hi Rodney, Have the vehicle scanned and diagnosed. That way you will know for sure where the problem is. I believe the problem is in the control system. Regards John
Jul 01, 2012 | Ford Expedition Cars & Trucks
Truck stalls sometimes when i backup then engage to drive it stalls a few seconds then jumps in gear also it makes a whining sound when driving but on the highway its fine somebody please help i changed...
That may be a stuck torque converter solenoid..Did you have scanned for transmission codes..Do you any lights flashing,,like the overdrive light??
Sep 30, 2011 | 2004 Ford F150
Transmission has intermittent problem with hard shifts, sometimes it acts as if its gone into neutral.....turning of the engine and restarting helps until the next time, which may not be for days...e40d...
Your check engine light should be on by now. First n foremost check to be sure the transmission fluid is guaged. Not too much n not less. Take note of color of ATF too if it due please change oil, I hope u ve been servicing ur transmission too. B4 taking shift solenoids off n all pls have the car scanned.
Sep 09, 2011 | 1994 Ford F150 Styleside Supercab
Transmission jumping and over drive light flashing ford contour 1996
If the fluid is full, it's most likely time to replace the transmission. How many miles are on the car? If you keep driving it like that, you will find yourself on the side of the road soon.
May 18, 2011 | 1996 Ford Contour
1992 Ford Bronco Transmission Problems (E4OD)
Here is what code E40D is:
TRANSMISSION - E40D - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR
TRANSMISSION - E40D - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS
TRANSMISSlON - E40D - SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR
1989-94 BRONCO, ECONOLINE, F-150-350 SERIES, F-47, F-53, F-59
here is possible fix:
ISSUE: Some vehicles may exhibit a shift concern and/or a harsh engagement concern due to water intrusion into the MLP/TR sensor and vehicle harness. There may also be a number of different DTC's along with those concerns.
ACTION: Replace the MLP/TR sensor and vehicle harness connector if signs of water is evident.
Jan 18, 2010 | 1992 Ford Bronco
Will 1995 transmission work in 1991
i would think you would be fine, just swap the computers for the trannsmission as well
Sep 24, 2009 | 1991 Ford Bronco
Hi,i have an 92 f250 7.3 diesel idi 4x4 with a blown E40D transmission,does anybody now if an E40D from a 94 f250 diesel 4x4 will work in my truck
yes they will i think all the way up until 97 they are the same could even be more year than that! but if you have a 94 you should have no issues putting it in the 92! good luck man and if you have any more question please ask...
Sep 17, 2009 | 1992 Ford F250
Tranny fluid capacity 95 F150 5.0
Automatic trans??? 2 or 4 wheel drive??
AOD 2 wd- 12.3 qts
AOD 4 wd - 12.3 qts
C-6 2 wd - 12.0 qts
C-6 4 wd- 13.5 qts
E40D 2 wd 15.7 qts
E40D 4wd 16.2 qts
4R7OW - 14 qts
Jul 27, 2009 | 1995 Ford F150 Styleside Regular Cab
1997 Ford e40d Transmission won't shift when warm
Take it back to the rebuilder, it should still be under warranty. But first, check the fluid level. Have it on flat ground, engine running and transmission warm.
Jun 12, 2009 | Ford E-250 Cars & Trucks
Worldwide 1994 Ford E350 Econoline Super 7.3L Alternator Logo
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
