Question about Sharp AR-5316 Advanced Digital Imager Copier
Samsung scx-3405w grinding noise
Grinding noise
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
How do I check the toner level on printer Samsung scx 3400 series?
on this model i do not believe you can check the level if you can it would be on one of the reports that you can print in your menu section.
Oct 03, 2014 | Samsung Scx-3405w Wireless Mono Laser...
How do i scan my papers to usa by samsung printer scx-3450w?
Hello there,
Firstly I MIGHT be wrong but there does not appear to be a Samsung scx-3450w !!!!!!!!!!!!!!!!!
I am hoping that you meant the scx-3405w
You can download the USER GUIDE by clicking here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=4840241&CDCttType=UM&ModelType=N&ModelName=SCX-3405W&VPath=UM/201111/20111124162204533/EN/english.pdf
Page 64 refers to scanning.
The main support page for this printer if you need software for it is here.http://www.samsung.com/uk/support/model/SCX-3405W/SEE
If I am wrong about the Printer Model....at least you have the right site there for support.
Sep 11, 2014 | Office Equipment & Supplies
Paper creases
I have the same problem with my printer.??????????
Feb 18, 2014 | Samsung SCX Office Equipment & Supplies
Do not have a manual for my recently purchased Samsung SCX340SF and cannot get the fax to work - please email me a copy of the manual
You may download a copy of the manual from http://www.samsung.com/us/support/owners/product/SCX-3405W/XAC#content2. I'm afraid I can't email it to you since you didn't publish an email address. Any private information you provided FixYa when you signed up is just that: private.
Aug 08, 2013 | Audio Players & Recorders
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Printer noise
check here to see if that upgrade is in their service support area yet..
Jan 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
