Question about Philips HR1861 700 Watts Juicer
How to remove filter from HR1863
I just bought this juicer and I am trying to take it apart just to check how to clean it. However I cannot get the filter out, is there a special technique? Louise
I bought a used one without a manual-I don't know how to take it apart and clean it, and beginusing it, thanks
Rotate the cover to remover it, unscrew the clutch
nut in the center of the blade and lift everything out.
If the juicer is stained, boil the parts in a solution of
Oxi Clean and water for a few minutes. They will
scrub up like new.
Oct 15, 2010 | Acme 6001 Juice Extractor
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
I can't take apart my new indulgence by mistral juicer for initial clean. I was able to take off the clear top and pusher and the pulp container, but can't get the filter out or spout.
i have a mistral mss25 air conditiioner and i need to clean the filters is the only the 2 large square filters or is there another somewhere which needs cleaning?
Jun 27, 2009 | Juicers
Cant get it apart
I bought this machine in a garage sale and i cant seem to take it apart.
Jun 20, 2009 | Jack Lalanne Power Juicer (Stainless...
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
Jun 06, 2008 | Jack Lalanne Power Juicer (Stainless...
Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Jun 03, 2008 | Juicers
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Philips HR1861 700 Watts Juicer Logo
59 people viewed this question
Top Philips Juicers Experts
David Payne
David Payne
Tom Chichester
Are you a Philips Juicer Expert? Answer questions, earn points and help others
