What is the wall mounting screw diameter for a Toshiba 40xv645u
My toshiba did not come with screws for the wall bracket, and the screws in the bracket packet are too small. Bought some 5/16'' and they look close, but won't thread into the TV holes. Are they metric, and if so, what are the diameter?
  • Anonymous Mar 26, 2014
    During a recent move we lost the base mounting screws for a Toshiba 40E220U TV. What size screws do I need?
Dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
  • MBF_1982 Oct 23, 2009
    After multiple trips to Home Depot I have finally fount the solution! You will need machine screws or bolts 8mm-1.25 x 20mm. I used hex head bolts with 8mm lock washers and it worked perfectly! In hind sight I suppose it would have been easier to use a micrometer or even a tape measure with a MM scale and just measure the holes from inside to inside...
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts
https://www.encompassparts.com/model/TBA40S51U/_/_/Toshiba/40S51U/Tv,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List - PartStore.com
https://www.partstore.com/Model/Toshiba/Toshiba/40S51U.aspx
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay
www.ebay.com > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Can the 19av500u be mounted on the wall
yes to find proper mount google 19av500u wall mount PLEASE make sure it is screwed into a 2-by-4 in wall
Sep 02, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
No screws are included for wall mount
we can not , as we can not measure the diameter of the holes thru the computer .
Oct 10, 2017 | Coby DVD-988 Theater System
Can i wall mount this
Usually, UMC include the screws already screwed into the wall mounting holes that you should use to attach a wall bracket. This is so you dont then go and use longer screws often supplied with wall mounts that are way too long and can damage the parts inside the TV.
Dec 18, 2008 | Toshiba 20HLV16 20 in. LCD Television
Televison & Video Logo
1,581 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
