Question about Hoover Dryers
Drum wont turn
Lights on and buzzing and drum wont turn
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
My Kenmore 70 Series Extra Capacity dryer wont start
there is several problems it could be the bearings in drum could be bad or there could be a sock or other item locking up drum from turning.
Nov 06, 2013 | Dryers
When start button is pushed the motor will buzz but yhe drum wont turn
Turn power off ,Will the bowl(drum) turn freely by hand.
If not turn by hand the bearings are seized,
It will need a seal & bearing kit & maybe a shaft as well.
Jul 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
Dryer drum wont spin, it makes a buzzing sound when started for 3-5 seconds then shuts down. Drum is locked up, can't turn by hand.
soulnds like ewither something jammed betwween the front felt and the drum, or perhaps a small item of clothing has felll into the fan assy
Feb 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
Motor buzzes drum wont turn.
Try checking the drum belt, it may have snapped!
Apr 10, 2009 | Frigidaire Dryers
Drum wont turn
Is your motor working? How about your belt? Is it broken?
Jan 24, 2009 | Dryers
Dryers Logo
12 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
