Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
What is the resoultion lines on this tv
What resoulutin does this tv have
I plug my ps3 into my sony lcd tv with a hdmi cable and it doesn't work. The screen is all blurry. But when i plug the ps3 into a different tv, then it works.
It may be that the resoultion of the ps3 is set to match the different tv. It could also be the settings on the first tv. verify that the resoultion settings are the same on both tvs.
Dec 24, 2010 | Televison & Video
Why does my platstation 3 display 1200x720 on samsung lcd tv when i put a game in. On my tv it display the out put on screen when ever i put in a movie our game.
your question is a bit unclear but here are some suggestions:
1 your tv doesent support 1080p or 1080i
2 it could be that the game/dvd is not in 1080p or 1080i
3 it could be your tv is set to minimize resoultions
i am not an expert i am just wingin' it here.
Mar 23, 2009 | Sony Playstation 3 (PS3) Console
My oil furnace is locking out what do i do
You need to change out the burner orifice, change the filter and make sure there is pkenty of oil. Bleed lines at brake like valve until there are no bubbles present.
Mar 02, 2009 | Honeywell Power Humidifier: Furnace...
Connecting pc to grundig32 tv - msg out of range
I am going to suggest with that message, the the TV does not understand the signals it is getting from the PC.
Reboot the laptop while connected to the TV, and turn the TV off, then On, while the PC is connected. If you continue to get the message, look in the manual for the TV to determine the reason for the message.
Jan 23, 2009 | PC Connection FastCAT 5e Patch Cable...
After using recovery disc and rebooting computer, the windows are larger than the screen. this happens to all the windows that I open. I have to continue using the arrows to align each window and even...
This is caused by the resoultion of the graphics card not being set to suit your monitor.
Right click on the desktop, and choose 'properties' from the list
a new dialog box will appear called 'display properties'
along the top is a series of tabs, the last one is called 'settings'
click on this and you will then see details of your screen resoulution.
Halfway is a slide bar called screen resoultion
for example..
less -------|------- more
move the slider untill the numbers change to 1024 by 768 pixels
to the right is another box called colour quality - change this to 'highest (32bit)
click apply
click ok
the screen will briefly go black then you will see the desktop, you will get a confirmation box asking along the lines of 'do you wish to keep these settings' click yes to this
have a play with the desktop, open some windows and see if they are now fully visable to you without having to scroll.
You can go back and change your resoultion anytime you want, by following the above. But take note, some monitors will not display all the resoultions in the list, you will get a message to say if it is or not. Just play with the settings untill your happy.
Hope this helps
Regards
Aug 14, 2008 | Sony Computers & Internet
Conecting Laptop to TV
Possibly the dual screen mode is turned off on the laptop, or the screen resoultion on laptop does not match that of what the TV requires.
May 17, 2008 | Televison & Video
How do I reset the resolution
Switch in menu_______ video back to VHF cable
Feb 17, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Video problems
change ur screen resoultion n try to make ur screens refrest to 60MHZ! if still ur problems not solving re-install windows
Nov 10, 2007 | EliteGroup P965T-A Motherboard
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
