Question about Ativa V-Series Ativa V180C 14-Sheet Cross-Cut Shredder
Shredder will work in reverse but not in forward
Motor work in reverse but doesn't work or has no power when switch is pushed for forward
The shredder only goes in reverse. I did oil it, but it doesn't work.
did you try to fix the forward problem by oiling it? That would be my first choice. The Forward and reverse switch would be my first thing to check to make sure the switch is working. Next would be the actual motor to see if it's getting power to go forward.
Oiling it won't fix the forward problem unless it was somehow stuck which would be unlikely since it goes in reverse.
Sorry I couldn't give you more help with this.
Good luck.
Mar 11, 2015 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
Blockage in forward
unplug it from the power then try to push out the blockage useing a scuwer
Apr 17, 2014 | Aurora World Aurora AS610C Cross Cut...
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
Shredder motor will run in reverse, but not
Sounds like a bad or dirty switch you can try to clean it with alcohol ( the switch that gets activated by the paper)
-Carl
Jul 06, 2009 | Fellowes Powershred 480 Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Won't shred
you have to replace the main power switch
Mar 31, 2009 | Fellowes Manufacturing FEL36055 Powershred...
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Ativa V-Series Ativa V180C 14-Sheet Cross-Cut Shredder Logo
Top Ativa V-Series Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Ativa V-Series Office Equipment and Supply Expert? Answer questions, earn points and help others
