Question about Samsung SCX-3405W Wireless Multifunction Mono Laser Printer/Scanner/Copier
Grinding noise samsun scx-3405w
Grinding noise after changing print cartridge
How do I check the toner level on printer Samsung scx 3400 series?
on this model i do not believe you can check the level if you can it would be on one of the reports that you can print in your menu section.
Oct 03, 2014 | Samsung Scx-3405w Wireless Mono Laser...
How do i scan my papers to usa by samsung printer scx-3450w?
Hello there,
Firstly I MIGHT be wrong but there does not appear to be a Samsung scx-3450w !!!!!!!!!!!!!!!!!
I am hoping that you meant the scx-3405w
You can download the USER GUIDE by clicking here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=4840241&CDCttType=UM&ModelType=N&ModelName=SCX-3405W&VPath=UM/201111/20111124162204533/EN/english.pdf
Page 64 refers to scanning.
The main support page for this printer if you need software for it is here.http://www.samsung.com/uk/support/model/SCX-3405W/SEE
If I am wrong about the Printer Model....at least you have the right site there for support.
Sep 11, 2014 | Office Equipment & Supplies
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Makes grinding noise on start up. Goes silent and makes same noise when printing. Any help on what is causing this? KC
Most commonly this is due to the gears that turn the various rollers not meshing properly due to a misaligned item in the chain, normally the gears on the toner cartridge. Make sure the cartridge is seated properly by removing and reseating it and try again. If it has been doing this for some time, you may want to visually inspect all of the readily visible gears for wear.
Apr 05, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Jun 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Samsung SCX-3405W Wireless Multifunction Mono Laser Printer/Scanner/Copier Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
