I cant connect it to direct tv - Televison & Video
    Master:
  • 397 Answers
Hi, I may be able to help, what device are you trying to connect to your TV?
Posted on Mar 20, 2014
How can I connect my phone to Panasonic tv
You cant connect your phone directly to your panasonic tv, it depends on the model . but.., if your tv has the usb optional socket input you can , all you need to do is to configure it , youll see it in your screen when accepted , and use the remote if the phone is detected.
Nov 30, 2016 | Panasonic Televison & Video
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
Jan 03, 2013 | Onkyo TX-NR609
I cant connect to the internet I have the cable going directly into the TV and I still cant connect to the TV can someone tell my why?
It is sad to say that Panasonic - 50" Model: TC-P50U50
lacks the ability to connect to internet.
It should have an Ethernet port.
Sep 29, 2012 | Panasonic Viera TCP50U50 50-inch Plasma TV
Cant hook up through my hdmi connection
You need to reset the PS/3... this resets the video out format
Aug 28, 2017 | Pioneer PureVision PDP-5050HD 50 in....
How do we hook up a Wii to the Sanyo DP42740 TV?
Hi Amy,
I cant see any specific connections for your tv but the end of the cable from your wii will have either a 21 pin sc"scart" connection or 3 plugs,(red, white and yellow) Look about on the back of the tv for corresponding socket. There should only be a couple of choices for each. Then simply plug it in. There will be no tuning or anything to do as these are direct connections. On your tv remote look for a button which will display or select the direct inputs. May look like a small screen shape with an arrow pointing into it, or may say "ext" or similar.
Hope this has been helpful
May 07, 2011 | Sanyo Televison & Video
Panasonic 42" connected to comcast dvr, and dvd player
To solve need more info if this is still a problem.
Is your comcast dvr connected directly to the tv, and also the DVD connected directly to the TV?
If so then you will need to change the input selection on your tv remote to determine which inputs these devices are connected to.
If you are connected differently, please post how your devices are connected.
Dale
May 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Hooked up my new aquos and cant get the cable to work, my wii comes on , my dvd player too, but the Direct Tv screen is just blank
How is the cable connected to the TV. Is it direct into the back of the TV or through one of the connections like say the wii? Did it work before with the way it is connected?
Aug 18, 2008 | Televison & Video
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
