Question about GE neral electric 45231 Home Monitor Wired Color Camera with Night Vision
GE 45231 W?
IRING DIAGRAM AND WHICH COLOR WIRE GOES WHERE
2 Suggested Answers
jadiazq
  • 2878 Answers
SOURCE: can i connect the GE 45231 Wired Color Camera to a computer?
A TV or VCR would use a RCA jack. You would need an adapter to VGA. However, there is still the problem of software. A computer TV card might be a work around, and they use to come with software.
I'm just pointing the obvious, but good luck anyway.
Posted on Sep 29, 2012
Wiring diagram for 45231c wired color camera security system was cut and wire is missing
Call the cops. This may be an indication that someone is planning to rob your home.
May 19, 2016 | GE 45231 Home Monitoring Camera
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
I just spliced open the wire coming out of the camera.it only has 3 wires.they are black,red,and yellow. so now i dont know witch goes where? need some help..
red & black is your power + & ground -. Yellow and black is your video and ground. you probably don't have audio if there is not another wire. If you have a shield wire around the others sometimes that is used for ground and in that case red and shield wire would usually be the power.
Feb 17, 2015 | GE 45231 Home Monitoring Camera
Can i connect the GE 45231 Wired Color Camera to a computer?
Sep 28, 2012 | GE 45231 Micro Cam Wired Color Camera With...
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Aug 26, 2012 | GE TIMER PLAS. SHAFT - WE4M366
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Looking far data sheet or equivalent circuit/connection diagram for a 97F9834 capacitor
You can find a datasheet located here. Page 14 contains your capacitor's information. As for a connection diagram, it's fairly simple. The dual capacitor (three prong) has a connection for fan, compressor, and common. Common (typically white) goes in the middle, compressor goes to herm, fan goes to fan. You should see the labels etched into the metal either on the side, top, or bottom. As for the colors of the fan and compressor, the brown wire should be for the fan, and the compressor's wire should be yellow. Of course, your system should contain a wiring diagram, which is usually attached to the door. Consult this diagram before assuming any wire colors I tell you are correct. Also, you should have some form of cutoff switch. Ensure this switch is OFF before doing ANY electrical work on your system. 220v in AC units WILL KILL YOU, especially coming off the capacitor. Best of luck!
Tj
Aug 18, 2011 | GE Heating & Cooling
Need to know how to wire the blinker box back in or whatever it is called. when i hit my blinkers all my lights flash. i found that the blinker bax wasn't ired in couldneed a wiring diagram to wire it back...
The service manual has a wiring diagram, but you will have to zoom in to read the wire colors.
You can download a free one at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
Nov 04, 2009 | 2000 Yamaha YZF-R1
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
GE neral electric 45231 Home Monitor Wired Color Camera with Night Vision Logo
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
