Question about GE 7 cu. ft. Chest Freezer FCM7DR
Frost build up
What temp should I set my freezer on
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Settings
The freezer should be set at 4 or 5 to start. If that is not cold enough then move the temp knob to 6 or 7 to get it colder. the higher the # the colder it will get. Onse you set the new temp it will take around 4 hrs to get to the new setting.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What is a reasonable temp setting for this freezer? Bought it without the manual. A quick version on how to set that temp would be helpful. Thx, m..
freezers should be -18/20C to keep beef for 12 months,use a freezer guage in centre of freezer,that way you wont get ice bricks instead of ice cream.....test after 24 hours of setting....
Apr 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE 7 cu. ft. Chest Freezer FCM7DR Logo
56 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
