Question about Heartway Venus Power Mobility Scooter
Hp6 electric wheelchair does it take an allen wrench or a key to make it move
Does it use a key or allen wrench?
Disposal makes noise but blades do not move,,,,,,,Help.
probably seized up They normally come with an allen wrench that fits in the bottom of the disposer. use the wrench to free up the impeller using back and forth pressure.
Aug 30, 2017 | Electrical Supplies
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
I have another puncture on my front on my Rascal 302 le how do a get my front wheel off
I am assuming you are talking about the castor wheels. You just need to remove the center bolt/axle. You will need a 5mm and 6mm Allen wrench. Once you get the screw out of one side, you should be able to push the axle out and drop off the tire for maintenance. This is generally a solid tire.
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
I have a puncture on my front wheel tyre on a rascal 302 le how do i get it off
Remove the axle and drop off the tire. Tools needed are a 5mm and 6 mm Allen wrench
What is the standard seat for MPV 5 and are the arms adjustable? If so, how?
set screws found in the elbow joints of the arms. the big T handle allen wrench will work
May 18, 2013 | Hoveround MPV5 Electric Wheelchair - Used...
Wrench lite comes on and scooter will not move. I have checked the electric hook ups, all OK. I wiggled the control stick and it move for just a few feet. What could it be?
The wrench light indicates a problem count the number of flashes ie 4 flashes pause 4 flashes indicate a motor problem See my tips on flash codes. Once you get the flash code then you will have to get the chair repaired because there is no self fix for those errors Hope this helps
Jun 10, 2011 | Electric Mobility Invacare Pronto M41...
A wrench light is on the indicator and the chair will not drive. Help! Thanks, Michael
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
May 31, 2011 | Electric Mobility Invacare Pronto M41...
Joystick not moving chair,a blinking light on keysign on joy stick panel
You need to check the little fuse and see if it is blown, if it is replace it, if not, it is like a 'check engine light' on a car, most of the newer chairs need a diagnostic test ran.... Guy
Sep 06, 2010 | Dmm Allure HP6 HD - Used Electric...
How to take off wheel mobility scooter. Is it the allen key studs on outside or is it underneath silver cover on centre of wheel
The wheel should be held on by 1 nut (or maybe bolt) in the centre of the wheel so in your case it sounds like its inderneath a centre cover. The allen key studs on the outside of the wheel (probably 4 of them?) will be to split the wheel in half to change a tyre or tube. When removing the wheel, if it is a rear wheel, be carefull not to lose the hub key which is located in a slot on the axle.
Mar 18, 2010 | Electric Mobility Mobility Electric Power...
Humms but blades don't move. the blades move freely. the reset button did not fix it. thank you.
Try placing the allen wrench into the socket on the underside of the disposer and working it back and forth, then trying it electrically. The blades can appear to be free, even with a jam. The moving of the inner workings with the allen wrench should free it all up. Flush the disposer with a potful of ice and water when it turns freely.
Best regards, --W/D--
Aug 12, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Heartway Venus Power Mobility Scooter Logo
26 people viewed this question
Top Heartway Health & Beauty Experts
Robin Hill
Robin Hill
ray gallant
Are you a Heartway Health and Beauty Expert? Answer questions, earn points and help others
