Question about Eagle SeaCharter 642C DF iGPS
Fix a connector
I need to replace my connector
Error code E000 0001
Dear
Its Fixing temperature abnormal rise.
1.Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the
power.
2.Check connection of the Connectors (Thermistor Connector
and AC Connector).
3.Replace the Fixing Main Thermistor (Film Unit).
4.Replace the Fixing Assembly.
5.Replace the DC Controller PCB.
Thanks.
Feb 02, 2015 | Office Equipment & Supplies
E000004 0205
check the info button in service mode. it will tell you all the possibilities for all ecode occurences.
Most likely a problem with your fixing drawer connector
It might reset and go away, or you may have to change connector
E004 0205 05 Title Thermistor temperature difference error Description of detection Difference of detected temperature between thermistors is bigger than the specified value. Measures 1. The connectors of the fixing main/sub thermistor (THM1-1 to 3) are physically removed (the cable is caught, or disconnected) -> replace the fixing belt unit 2. Check the rotation of the fixing motor (the connector is physically removed or disconnected) -> replace the fixing motor or the harness3. The connectors of the pressure sub thermistor (THM2, 3, 4) are physically removed (the cable is caught, or disconnected) -> replace the thermistor or the presure stay 4. Disconnection, soiled, improper location of, or faulty pressure sub thermistor -> clean the thermistor or replace it5. Faulty drawer connector -> clean the drawer connector or replace the fixing drawer cable6. Replace the DC controller PCB
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 06, 2014 | Canon imageRUNNER iR C4080 Color Copier
E000002 in canon 2525
Go through the following to clear the error: clear>ENGIN>ERRCLR turn OFF and then ON the power.
Check connection of the Connectors (Thermistor Connector and AC Connector).
Replace the DC Controller PCB (PCB4).
May 27, 2013 | Office Equipment & Supplies
MY HARLEY DAVIDSON FAT BOY 2002 IS LEAKING FUEL AT THE GAS TANK QUICK CONNECTOR. HOW TO FIX THAT??
Is it coming from the inside of the connector or between the connector and the tank? If its between tank and connector its an O-ring issue. If its internal of the connector you will need to replace the whole Connector.
Mar 31, 2011 | Harley Davidson FLSTF - FLSTFI Fat Boy...
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
I pulled the TV/Cable TV/HDTV input connector out of my VIZIO TV. How is it fixed.
Hello; You will need to replace the PCB with the tuner on it. The RF connector that you broke off is almost always a part of the tuner and replacing the connector is NOT recommended. John
Jan 09, 2011 | Vizio Televison & Video
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
Need your help
The problem with this code is in the fuser area. I don't have the specific manual for this model, but here's some information from a Canon IR3250 manual: III . Troubleshooting Malfunctions A. Error Codes 1. E000/E003 Thermistor 1) Is the thermistor soiled? YES: Clean the thermistor. Is the thermistor in even contact with the fixing upper roller? NO: Mount the thermistor correctly. Turn off the power switch, and remove the fixing assembly. Measure the resistance between connectors J50B-2 (FSRTH) and J50B- 3 (GNDTH) on the fixing assembly side. Is it between 120k and 290k W? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Main heater 2) With the fixing assembly removed, is there electrical continuity between connectors J50-3 (FSRN1) and J50-5 (FSRL1) on the fixing assembly side? NO: Replace the main heater. Sub heater 3) With the fixing assembly removed, is there electrical continuity between connectors J50-4 (FSRN2) and J50-5 (FSRL2) on the fixing assembly side? NO: Replace the sub heater. Thermal switch, DC controller PCB 4) Remove the fixing assembly, and detach the wiring cover. Is there electrical continuity between the terminals of the thermal switch? NO: Replace the thermal switch. YES: Replace the DC controller PCB. CHAPTER 4 TROUBLESHOOTING COPYRIGHT © 2000 CANON INC. CANON iR3250 REV.0 JUNE 2000 PRINTED IN JAPAN (IMPRIME AU JAPON) 4-43 2. E001 Thermistor 1) Turn off the power switch, and remove the fixing assembly. Then, measure the resistance between connectors J50B-2 (FSRTH) and J50B-3 (GNDTH) of the fixing assembly side. Is the resistance 1k W or less? NO: Check the wiring from J222 on the DC controller PCB to the thermistor; if normal, replace the thermistor. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 3. E009 Fixing assembly 1) Is the fixing assembly rated at a voltage different from that of the power supply? YES: Replace the fixing assembly so that its voltage matches the fixing assembly. Power supply assembly, DC controller PCB 2) Replace the power supply assembly. Is the problem corrected? YES: End. NO: Replace the DC controller PCB. 4. E010/E011 Connector 1) Is connector J12 of the main motor and connector J218 on the DC controller PCB connected correctly? YES: Connect them correctly. CHAPTER
Jul 02, 2007 | Canon imageRUNNER 3570 Copier
Eagle SeaCharter 642C DF iGPS Logo
16 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
