Question about Craftsman Garden
Weedeater WLT24 not holding a charge
Purchased last year and had no issues until now. Will only hold charge for about 5 minutes and then is very slow and won't trim. Found several complaints online regarding same product, but no mention as to how to fix. Any thoughts as I am not very technical but can usually work through an issue if explained. Any help is appreciated.
Purchased at Walmart last season., not named but is green and yellow, so possibly craftsman??
SOURCE: battery
battery is dead, maybe you need to ask for the guarantee
Posted on Sep 10, 2008
canbruce75
  • 1776 Answers
SOURCE: Craftsman 34cc 4 cycle weedwacker will not start
Start by removing and cleaning the spark plug. The check out the screen at the exhaust port and make sure that it is completely free of carbon build-up. I never run my equipment out of gas at the end of a season, I usually add some fuel stabilizer to the gas and run some into the carb before shutting down for the season. Hope this helps and good luck.
Posted on Jul 11, 2009
  • 138 Answers
SOURCE: weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Posted on Sep 24, 2009
Dolfoff
  • 148 Answers
SOURCE: Weedeater Head won't Turn?
If less than a year old, and you can verify such...
Read Troy-Bilt Warranty Policy here.
Click on "GET ANSWERS" under the heading of customer service on the left side of the page.
Posted on Sep 29, 2009
rycgl
  • 1545 Answers
SOURCE: I have a craftsman 32cc
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Posted on Aug 23, 2010
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
Jul 09, 2016 | Sony Walkman Audio Players & Recorders
How often can you charge the battery on a Invacare ATM
Charge as required , Battries usual to last Max 5 years ( they don't make them like they used to ) Bottom line , Battries can DIE at any time . so use / charge then untill thet will not hold a charge.
Mar 12, 2015 | Invacare Health & Beauty
TOMTOM ONE -ABOUT 5 YEARS OLD NOT SHOWING ON LIST OF DEVICE, DOES NOT USE A CARD. PROBLEM-CANNOT SWITCH IT ON. Help!!
First, make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Sep 03, 2011 | Tomtom GO 910 GPS Receiver
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Got a replacement battery not long after I bought this weedeater. The replacement battery would not hold a full charge [unless it is supposed to last only 10 minutes]...however, I lived with it. Well now,...
The replacement battery should have come with a WARRANTY, e.g., 30 days or 90 days or 1 year.
Exercise that warranty to get it inspected/repaired/replaced.
How old is the weed-eater? Has its warranty expired? It could be a problem with the battery-recharger.
Jun 06, 2011 | Computers & Internet
I just purchased a John Deere Gator at a garage sale. I have charged it until the green light comes on the charger, buy it does not hold the charge for longer than 10 minutes. Do yo have any suggestions
These small batteries do not last very long. Your best bet is to buy a new one, depending on how much you use it it will last between a year and four years. Unfortunately these batteries are also expensive, they run from $70.00 to $110.00 depending where you buy them. I have had the best luck at WalMart they go for the best price and they are good about honoring warranties on their batteries.
May 11, 2011 | Peg Perego 12 Volt Rechargeable Battery
My battry is not charging properly.it goes upto 100% and the charge is finished in 4 or 5 minutes
Laptop batteries worn out with the passage of time and their charge holding capacity decreases.
The battery now has very less charge holding capacity (equal to 4-5 minutes), that's why it says it is 100% charged (capacity of 4-5-minutes).
So, it is recommended to replace the battery with original battery as it would last longer and serve you better.
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Dec 15, 2010 | Compaq HSTNNLB42 Laptop Battery
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at https://register.ryobitools.com/contact_us/new
Nov 03, 2010 | Ryobi Multi-Volt Battery Charger
Battery
Aug 14, 2008 | Black & Decker String Trimmer Cordless 12"...
HS850 charge doesn't last long
Sounds like you've got a defective model. Mine lasts about 4-5 days before I have to charge it.
Apr 10, 2007 | Motorola Mobility HS850 Consumer Headset
Garden Logo
340 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
