Question about Honeywell Ademco Alarm 6150rf Keypad Lk
How do I change battery in alarm system
APX alarm keeps beeping low battery
  • 57 Answers
Find the main box that has the alarm control board in it. This panel can have a 12v 4ah battery or a 12 7ah battery. Unplug the old one, plug in the new one. Make sure you put the black to black red to red it doesn't matter what order but if you do it backwards then you'll have to guy buy some small fuses. GIve it about 12-24 hours and it should clear from the keypad.
Posted on May 17, 2014
3 Suggested Answers
  • 8457 Answers
SOURCE: APX alarm system reads low
The backup battery that help the system keypad/receiver unit to operate it is low in power and it is dying and in need of a new battery replacement.Traced the system back where main junktion and overide to the system box unit is should have the battery there.This battery really easy to do a replacement.The battery it is like a similar to a motor cycle battery.
Posted on Jul 21, 2011
  • 78 Answers
SOURCE: i changed the system battery for my alarm but it
Run a sensor test on system. Enter your code then 5 + 0. Be aware that if you have a a siren it will go on for a second. Let test run for about 3-5 min or until it resets. GL.
Posted on Apr 23, 2011
My Scorpion Z6 house alarm system, with fire alarms attached, beeped during the night for no apparent reason. All contoller lights were correctly on indicating it is not a battery problem. I think the beep...
I'm not familiar with your system... but, I'd suggest changing any and all batteries, if it happens again. I don't know about your controller lights, but I do know that the battery does not have to get very low in an alarm before it starts giving you an occasional warning chirp.. If your battery or batteries are over a year old, you should change them, anyway. If a new battery (batteries) doesn't fix your problem, you might try vacuuming or blowing some air into the works on the chance you might dislodge some foreign particle that might be causing this. That said, though, I have had to trash fire alarms that did just how you're describing... because, no matter what, I couldn't make them be quiet.
Nov 14, 2013 | Home
How to stop dicon smoke alarm beeping
All smoke alarms beep if the battery is too low. Getting a used battery isn't good enough for smoke alarms. Even getting a new battery from a dollar store (a cheap no name brand import store) will not do... it has to be the newest and it has to be alkaline. once you put it in... press the button for 10 seconds... first you will hear it's own alarm then you will hear the others attached to it in the whole system chime in (if you have that type) the alarm will now sit quietly.
Oct 20, 2013 | Home Security
APX alarm system reads low battery,what do we do?
Jul 21, 2011 | Honeywell Ademco/ Honeywell 6150rf Apx...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Sytem will beep every three hour or when we open the main door
Check batteries in patio door are in correctly and are good. I know you said you changed them all. but if batteries are in correctly and are good try taking them out again waiting 20 sec putting them back in. If they are bad or low most likely a bad sensor shorted the out. replace part.
Jan 21, 2010 | GE Security Simon 3 Wireless Home Security...
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
Alarm system is not activated we just bought the house and it keeps beeping off and on how do we stop it?
I would try and get the owners manual for the alarm system and see what it says about the beeping. It could be that it is just telling you it needs a new battery installed, something like the battery operated smoke detectors do when the battery is low. There are so many alarm systems out there that it is hard to tell what could be causing the beeping. It could have been configured with a audible alert that when the system is tripped by any motion it beeps when off. It is really hard to say without the manual. You can usually find the manuals on line at the manufacturers website. Good Luck, RAC
Apr 20, 2009 | Computers & Internet
System Low Battery Alarm
You can silence trouble beeps by arming and disarming the system or by pressing status button; however, trouble beeps resume after 4 hours if the trouble condition as not been fixed. You can turn the trouble beeps off in the programming option 40. This should be done by your security professional because any mistake you could change other parameters in the system and the system may not work correctly. Hope this helps
Aug 19, 2008 | GE Security Simon 3 Wireless Home Security...
Honeywell Ademco Alarm 6150rf Keypad Lk Logo
350 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
