When i try to copy data to and from the hard disk, after a while it shows a message "USB device could not recognized" i am using windows Vista. i face this problem only from my PC. i used this HDD from many other PCS, but it doesnt has this problum.. (HD-PF500U2)
  • 52 Answers
Try to change the usb port used, use a shorter cable to connect you're drive or change the cable ..it may be damaged.
Posted on Jun 14, 2009
How can I get Windows 10 to recognize a Seagate 3TB External hard drive?
sorry but anything I tried with windows 10 failed and I went back to old OS thru the control panel and did a recovery .
Oct 27, 2015 | Seagate 3TB Expansion External Desktop USB...
Completed with errors message when creating safety drillll copy
how to recover raw drive data
How to recover "raw" drive data:
When a hard disk drive bracken or loss her partition and if you try open this drive then you got this message "Disk not formatted" .
At the times you should use any "raw" data recover software .
or
use recover "partition damage" software download.
recover everything
Nov 10, 2013 | Maxtor OneTouch 4 Mini 120GB External USB...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
I have a SimpleTech 1TB hard drive and I have alot of important documents on it. Everytime I plug it in a message comes up saying that the "Usb device is not recognized" I hooked it in a couple...
Let's try to get it recognized. I Presume you are using Windows... Make sure that your drive is connected and turned on. Go to your Control Panel, Then " Add Hardware". Just follow the prompts from there. To make sure it's recognized, go to your Desktop. Press "Start " and right-click " My Computer ". Now go to the last entry " Properties " , Then " Hardware " then " Device Manager ". If it still doesn't show them, I'll suggest you check your cables. Hope this helps. If so, don't forget to rate the answer please.
Jul 08, 2011 | Computers & Internet
My LaCie Rikiki is no longer recognized by Windows Vista or Windows 7 (tried mounting it in different computers) and is either doing beeping or clicking noises, depending on which computer and USB I...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Some USB-connected devices don't show up as drives
Hey Kunal,
This is not unusual windows will only recognize the standard memory cards not any custom ones or inbuilt ones. For example if your device is using a SD memory stick it will show up in explorer however if you are using a device that has a copyright or custom it wont. I am surprised the digital camera is doing the same thing as thy use mmc cards which are standard and should show up.
With these devices when you connect it to a pc you would get an option on the lcd on the device that would need you to confirm connection. may be thats what you were looking for. If you have a memory card reader you can try using that as well.
Please rate if this fixed it or was helpful.
If i missed something let me know.
Feb 11, 2009 | Microsoft Windows Vista Home Premium with...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Kingston USB 4GB
sounds like a bad hard disk or a malware virus interceptiong all data and corrupting it.
try www.hdtune.com free home version. if in health tab shows yellow. start looking for a hard disk
try in start, run (type) chkdsk /f black windows shows. press Y then enter reboot. see if it finds corruption. if its data not physical damage, it might fix it!
for virus malware issues i usualy head to majorgeeks.com for top 10 dloads and forum help.
Oct 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
