Question about Samsung LN-T1953H 19 in. LCD HDTV
Having a problem with HMDI input on back mtv
No connection when tv is turn on
How do I connect my TV to blueray
plug blueray device output into hdmi input of tv and then change input select on TV to HDMi 1 or HMDI 2 or HDMI 3
Dec 17, 2016 | Televison & Video
My hdmi is on my pioneer vsx 523
The HDMI inputs are on the back upper left of the unit. the 4 on the left are INPUTS (like you connect you DVD to port 1) then you need a 2nd HDMI cable from the white 5th port going OUT to your TV HMDI port.
http://www.pioneerelectronics.com/StaticFiles/PUSA/images/Product%20images/Home/VSX-523_back.jpg
Dec 07, 2016 | Pioneer Audio Players & Recorders
My th-42px80u Panasonic plasma tv has no picture or sound red light stays on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 17, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
How do i turn on hdmi cable
run hdmi to the tv and the other end to your receiver
Jul 04, 2014 | Toshiba 19HLV87 19 in. LCD HDTV
What video "input" sockets are on the side/back of your TV -- HMDI? S-Video? VGA ? Composite? Component? Coaxial?
What video "outputs" does your computer have -- HDMI? S-Video? VGA? Composite? Component? Coaxial?
Have you considered using a Google "ChromeCast" device -- it connects to a HDMI-input on your TV, and software on your PC wirelessly transmits the video signals from your computer to your wireless router to the wireless-receiver inside the ChromeCast ?
Mar 26, 2014 | Televison & Video
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
Feb 16, 2012 | Mitsubishi Televison & Video
How do I connect my samsung tv to a kenwood av 6000 using a HMDI cable
To do that you would connect one end of a HDMI cable to one of the HDMI inputs on the TV and the other end of the HDMI cable to the HDMI OUT on the Kenwood. Of course there are other considerations to make the whole process work successfully such as making audio adjustments on the Kenwood and selecting the proper input on the TV. Also having a source (video/audio) input on the Kenwood.
Apr 01, 2011 | Televison & Video
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Samsung LN-T1953H 19 in. LCD HDTV Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
