A
Anonymous Posted on Mar 19, 2014
The chemical formula for table sugar is C12H11O22. What can you tell from this formula?
Grrr
1 Related Answer
jerry_kramer
Jerry Kramer
  • 3933 Answers
  • Posted on Nov 09, 2015
SOURCE: What is the proportion of table sugar to dextrose to equal same amount of sweetness?
I actually would do this by testing and tasting. Not hard to do with a couple glasses of water. Mix in one tsp of sugar in one glass and in the other keep adding the substitute until it tastes the same or close. That will give you your ratio.
Testimonial: "Thank you!"
Why are we not naming the blame where it rightly belongs?
for social comment , use a social media
fixya site is for technical questions
Nov 09, 2015 • Cooking
How many teaspoons in 200 grams of caster sugar
There is no direct conversion from teaspoons (volume) to grams (weight) unless you know what product you're using.
this site: shows caster sugar 1 cup = 200 grams. or 48 teaspoons.
Baking Conversion Table
What does chemical symbols mean?
Are you talking about chemical formulas, reaction symbols or the elements on the Periodic Table?
Where is serial number and mfg date on bissell 73h5 machine
On machines: The serial number is located on a white label like this. It is usually located at the lower back or bottom of the machine (for Lift-Off models - remove Lift-Off pod to locate), or behind the cleaning tanks.
On cleaning formulas: cleaning formulas do not contain serial numbers. Instead, please enter the full number from the UPC code. Look for it on the back of the bottle or can, near the bottom. Here is a sample:
[img title="upc-on-chemical" alt="upc-on-chemical" src="http://www.bissell.com/uploadedimages/Asset_Library/images/Customer_Support_images/upc-on-chemical.png">
Write down the equation for the formation of the complex trans-K[Cr(C2O4)2(H2O)2.3H2O from the reactants K2Cr2O7 and H2C2O4.2H2O.
limiting reactant:
The limiting reagent, or also called the "limiting reactant", is the chemical that determines how far the reaction will go before the chemical in question gets used up, causing the reaction to stop. The chemical of which there are fewer moles than the proportion requires is the limiting reagent.
Limiting reagent formula
There is a much simpler formula which can be used. However, you must first calculate the moles of both of the reagents in the reaction. Once the number of moles have been figured out, just simply fill in this equation (reagent 1 being the first reactant and 2 being the second):
When the answer to the formula is less than zero, reagent 1 is the excess reagent. When the answer is larger than zero, reagent 1 is the limiting reagent. The number shows how much in excess one reagent is from another. If the answer for the formula is zero, both reagents are perfectly balanced. The unit of an answer is in moles.
Can you please define these words for me? (science) Dissolved, solvent, solute, chemical reaction, concentrated, saturated, dilution & crystallisation.
Dissolve - Think about how you put sugar into cofee, the sugar disolves into it, so you don't drink sugar pieces.
Solvent - is a substance used to disolve stuff. For example acetone disolves plastic in general, so you do not use it to clean your camera.
Solute - is a disolved substance. For example sugar in the cofee after it's been dissolved.
Chemical reaction - When you mix 2 chemical elements that have an action one to another, a chemical reaction happens. For example if you put Sodium in water, it releases hidrogen and heat (often the hidrogen ignites)
Concentrated - if you put too much sugar in your cofee, you say it's too concentrated.
Saturated - the moment you add more sugar to the cofee, and it just does not dissolve, you say the cofee is saturated with sugar.
Dilution - Reducing the concentration of a chemica. Adding more cofee to a saturated cup, is diluting it.
Crystallization - is the natural or artificial process of formation of solid crystals in nature or lab. For example the formation of ice crystals. More on the wikipedia page HERE.
2answers
EXCEL ALL SHORT FORMULA
hiiiiiii
u know vlookup function,then piviot table
u know na tell short formula
genious...
2answers
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
k24674
ADMIN Andrew
ADMIN Andrew
